1996 PSD Electrical Issues
Old Jun 27, 2011 | 09:55 PM
JTS1975's Avatar
JTS1975
Hello! I am hoping someone can give me some help bc these issues are driving me crzy. I had a GPR short, which in turn melted the plug that inserts into the valve cover gasket on the driver's side. Changed the GPR changed the gasket, changed the plug. Put it all back together and started the truck and it ran like crap w check engine light on. Ran code and got something like exhaust pressure sensor and number 8 injector low circuit. A buddy of mine told me to unplug the fuel injector and when I did she roared to life and the check engine light went off. I replaced the wiring harness to the injector and still the same issue. I next changed the IDM and let the truck idle for 30 bc the batteries were dead. After 30 minutes the truck started doing the same thing. Just happened to touch the GPR after this and it was scolding hot. Also noticed there was no buzzing sound when I went to start engine. Replaced GPR and heard buzzing started truck still had same problem w #8 injector plugged in. Unplugged it and she ran fine. Noticed the GPR was extremely hot again and not buzzing anymore. I am banging my head here. Any suggestions?
<!-- / message -->
<!-- controls -->
Old Jun 28, 2011 | 06:22 AM
Josh88Ford's Avatar
Josh88Ford
might be better off asking in the obs powerstroke forum.
Not sure if this is the problem, but have you heard of the 50 cent mod? Basically stick a quarter in the valve cover harness to keep it from comming loose.
YouTube - &#x202a;7.3 Diesel Powerstroke misfire runs rough code P1316 injector wire harness connection&#x202c;&rlm;
Old Jun 28, 2011 | 08:53 AM
JTS1975's Avatar
JTS1975
JOSH, I will def try the quarter trick. I just don't understand why when I put the other IDM on she ran fine for like 30 min. Any suggestions on why that GPR is getting so hot.
Old Jun 28, 2011 | 09:23 AM
Lazy K's Avatar
Lazy K
1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums Here is a link to the PSD page. As your problem is engine specific you would probably be better posting there.
Not sure about the relay getting hot, maybe the controller is bad and keeping the relay engaged.
Old Jun 28, 2011 | 09:51 AM
JTS1975's Avatar
JTS1975
Lazy K I posted it over there thank you.
hutch05
Dec 4, 2011 09:04 AM
JTS1975
Jun 29, 2011 10:20 AM
Thewiller
Jun 24, 2010 04:05 PM
puck1263
Electrical Systems/Wiring
May 20, 2010 04:50 PM
