GPR HOT/P0280 CODE
Old Jun 27, 2011 | 06:14 PM
JTS1975's Avatar
JTS1975
GPR HOT/P0280 CODE
Hello! I am hoping someone can give me some help bc these issues are driving me crzy. I had a GPR short, which in turn melted the plug that inserts into the valve cover gasket on the driver's side. Changed the GPR changed the gasket, changed the plug. Put it all back together and started the truck and it ran like crap w check engine light on. Ran code and got something like exhaust pressure sensor and number 8 injector low circuit. A buddy of mine told me to unplug the fuel injector and when I did she roared to life and the check engine light went off. I replaced the wiring harness to the injector and still the same issue. I next changed the IDM and let the truck idle for 30 bc the batteries were dead. After 30 minutes the truck started doing the same thing. Just happened to touch the GPR after this and it was scolding hot. Also noticed there was no buzzing sound when I went to start engine. Replaced GPR and heard buzzing started truck still had same problem w #8 injector plugged in. Unplugged it and she ran fine. Noticed the GPR was extremely hot again and not buzzing anymore. I am banging my head here. Any suggestions?
lvin4jc
Apr 12, 2015 07:52 AM
BillyBob69
20
Jan 27, 2015 07:48 PM
sammydiesel13
Jan 5, 2014 09:31 AM
LCA078
Dec 11, 2013 06:23 AM
Josh88Ford
16
Dec 9, 2013 06:38 PM
