2005 6.0L will not start
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1 itxtNodeId="685"><!-- / icon and title --><!-- message -->I have a 2005 6.0L that stalled will driving and will not start. I had a code P0611 so I checked the voltage and while turning the engine over I was reading 30V. I sent the unit out for repair, re-installed and the engine still will not start. Rechecked the voltage and I am reading 48V.
I am now getting DTC P0232, P0611 & P2617.
Can anyone help me diagnois what the problem maybe now?
Thanks!
Jeff
<!-- / message -->
Here is a link to the no-start thread in the Tech Folder, of course you can skip ahead a bit on some items (like if you don't have a security system for example) but good info to get you on the right track. Post back if you have any questions.
Good Luck!
https://www.ford-trucks.com/forums/8...condition.html
P0232- fuel pump circuit high
P0611- FICM performance
P2617- Crankshaft position output circuit open
I would think the P2617 would be first on my list. Check the harness first then check the tech folder for testing instructions. The P0611 could be left over from the FICM problem you had earlier, did all three connectors "click" when when you re-installed it? They can be a pain. P0232 Fuel problem will keep you from cranking also, is the pump running when key is first turned to run position?
Have you clear codes since FICM was re-installed?
