Auto Locking Hub problems
Old Jun 27, 2011 | 09:23 PM
Duck Hunter81's Avatar
Duck Hunter81
This weekend I was pulling a trailer up a gravel hill and had to put it into 4x4. My buddy decided that it would be better to Lock in 4x4 at the hubs and when he did, the auto locker dial siezed up. Since then it has been stuck in lock and I can't get it undone so I am currently pulling it to try and fix it. I noticed that I have some rubber seal sticking out between the dial and aluminum housing. Reading Guzzles lube and rebuild section it sounds like there are no replacement seal. My question, do they have rebuild kits or am I going to have to order me some warn hubs?
Old Jun 27, 2011 | 09:39 PM
snakedoc's Avatar
snakedoc
i think new one. there not rebuild
Old Jun 27, 2011 | 10:13 PM
clux's Avatar
clux
Doesn't guzzle sell the o-rings for the hubs on his website?
At any rate, if the o-ring isn't torn all you need to do is disassemble it lube the o-rings with some silicone lube.
Old Jun 27, 2011 | 10:19 PM
Duck Hunter81
Just pulled it apart and the rest of the seal fell out and it turns freely now and is out of 4x4. Looks like I will be putting an order in with Clay tomorrow.
Do the warn hubs stick out as far as the stock or will they look funny not sticking out past the plastic?
Old Jun 27, 2011 | 10:38 PM
snakedoc's Avatar
snakedoc
if it is the oring pic 1 you can get a new one but if it is the seal that is behind the *** pic 2 than that is bad.
http://www.guzzle7pt3.com/pics/ahs05.jpg
http://www.guzzle7pt3.com/pics/ahs13.jpg
Old Jun 28, 2011 | 12:27 PM
Duck Hunter81
Unfortunatly it is the seal behind the **** which is going to force me to replace it.
Old Jun 28, 2011 | 01:24 PM
snakedoc's Avatar
snakedoc
that is what i was think you said but did not wont you to buy new ones if it was just the oring.
Old Jun 28, 2011 | 02:13 PM
honeydew's Avatar
honeydew
I've got the warn premiums and just went back to stock wheels. The do look funny with the stock caps. The hub face is recessed and there is a gap. Ordered a pair of 05-07 center caps from ebay hopefully those look better.
Old Jun 28, 2011 | 04:37 PM
SteveH-CO's Avatar
SteveH-CO
They will look much better with 05-07 center caps - fear not.
swmpbgy1
Aug 16, 2016 09:48 AM
agsmv1
Jun 4, 2015 02:45 PM
cattlerancher
Nov 27, 2014 08:43 PM
Beeler
31
Dec 27, 2012 10:20 AM
EXv10
Nov 6, 2009 11:44 AM
