C-6 To E4OD conversion
Old Jun 28, 2011 | 01:27 PM
Rogue_Wulff's Avatar
Rogue_Wulff
It does take a bit of adapting to make it work, but it can be a cheaper route than the full stand-alone controller. The stand-alone is pretty much plug and play, while the factory IDI requires a bit of tinkering. If you're like me, time is far more available than money.......
Old Jun 28, 2011 | 02:39 PM
MUSKRATT2's Avatar
MUSKRATT2
Amen! My next question is, do you know anybody that has done it for me to talk to?
Old Jan 25, 2012 | 12:50 PM
RAY1986F150's Avatar
RAY1986F150
Well, I ended up with a FREE E4OD transmission the other day......it needs rebuilding. So, if I get it rebuilt what else will I need for the converstion? I plan on pulling a driveshaft from another truck to get the length and yoke right. Now, what all is involved in the controller? Do I just find a j/y controller?
What about the speedo? I see on this E4OD there is a block off plate where the speedo cable bolts to....is there a speedo gear inside there?
Thanks for any help guys........
I don't plan on doing this soon, just want to start researching and collecting parts. Thanks!
Old Jan 25, 2012 | 01:03 PM
Rogue_Wulff
I can't really help on the controller, aside from having heard that the IDI controller can be adapted to an older gas or diesel engine that lacks a computer. Not sure how much different it would be for the EFI system used in 85/86. This ECU is not compatible with the trans controller from a later EFI engine, as I understand it.
As for the speedo gear question, pop the plate off and look inside. It wouldn't surprise me to find a drive gear cast into the output shaft. The E4OD came along prior to the electronic speedo.
I've heard that this trans can be used with a V8 conversion in a 93+ ranger by swapping the speed sensor from the trans into the E4OD. The ranger speedo is driven by a sensor inserted into the speedo cable hole, and uses standard speedo gears to calibate. This would seem to indicate the drive gear exists in the E4OD......
Old Jan 25, 2012 | 05:44 PM
Gary Lewis's Avatar
Gary Lewis
Oddly enough, Ray, I was reading this thread to figure out if it answers the question you asked in the PM to me. And, now I see you are "in the loop" already. Good deal. I'll back out and leave you with it.
BigMightySam5600
Nov 22, 2015 06:26 PM
hauswulf
Oct 16, 2015 10:02 AM
TMScouts
Aug 11, 2015 07:45 AM
CantDrive55
Aug 20, 2007 08:18 PM
vols_fan22
May 9, 2006 10:58 PM
