5.0 missing
Old Jun 26, 2011 | 09:34 AM
robramsey's Avatar
robramsey
5.0 missing
hello, i have a 90 5.0 with a carb and dura spark ign, it misses at low rpm has any one had this problem and a fix thanks rob
Old Jun 26, 2011 | 10:39 AM
Boba Fett's Avatar
Boba Fett
Yes..... I have had trouble with this in the past.... Most of the time I have found it was only a loose wire boot at the plug.
If you have one of those testers that you use over the wires to look for spark start there.... A lot of the time they show all the wires working. If one isn't look over the cap..... If all the wires are firing the check the connection to the plug.... Most of the time the metal end on the wire is not tight on the end of the plug....
If one of the wires I'd not working it could be bad, or the cap might be bad...
The look at the plug as the culprit.... It could be dead as well
Old Jun 26, 2011 | 10:48 AM
Boba Fett's Avatar
Boba Fett
Also if you have a sputtering miss..... Look up wiring in Duraspark.... There is an additional ground that can be made off the box the factory neglected to make which makes it work a little bit better....http://www.therangerstation.com/tech...rasparkII.html. This is the basic wiring diagram.... A ground to frame or body for the black line is an upgrade.... It's called ignition system ground on the diagram
Old Jun 26, 2011 | 05:37 PM
robramsey's Avatar
robramsey
does the dura spark need a resistor,or does it need 12 volts i checked the plug boots and i ran aground from the box to the frame thanks rob
Old Jun 26, 2011 | 07:34 PM
Boba Fett's Avatar
Boba Fett
Duraspark does not need a resistor.....
Old Jun 26, 2011 | 07:36 PM
Boba Fett's Avatar
Boba Fett
If it still persists it could be a plug....
Old Jun 27, 2011 | 05:43 AM
robramsey's Avatar
robramsey
5.0 missing
would like to thank you all for the input i think this will help alot thanks again rob
Old Jun 27, 2011 | 08:18 AM
Boba Fett's Avatar
Boba Fett
The last thing to check is the charge of the alternator.... You can put a voltmeter on the battery posts to check it.... Or use the big lug on the alternator and the negative battery terminal.... You are looking for 14.xx...... You need a min of 12 anything less stuff like the ignition will not run correctly..... If it shows less then use the throttle to bump up the rpms and see if it increases.... Also check it after driving... New alternators need to be run a bit before they reach max output at idle.... Sometimes it's also jump over 2500 rpms....
If after all that it still doesn't go away pull the valve covers and look for a loose rocker arm....
Old Jun 30, 2011 | 05:40 AM
robramsey's Avatar
robramsey
5.0 missing
hello well after i took the resistor i took it out for a drive runs smooth with no miss so i thank you rob
BILLYBOB168
Sep 24, 2014 11:37 PM
FordYoungGun35
Mar 11, 2013 09:41 PM
mike L
Jan 21, 2010 04:29 PM
gotgrouper?
Aug 11, 2003 07:49 PM
Nov 1, 2001 10:46 AM
