Exhaust manifold remove/reinstall questions
In my never ending battle against smoke and high EGT's, I decided to tackle my leaking exhaust manifolds. I knew the driver's side was leaking pretty good around #8, but I found the passenger's side was leaking a little around #7 after I got it off. My questions:
1) I'm having a machine shop resurface the manifolds. What do I need to do to the mounting surfaces on the heads? I saw one post where a guy hd cleaned his up, but he didn't say how he did it.
2) What kind of high temp anti seize or grease works best?
3) How on earth do you get the fender liners reinstalled in one piece? Did any of you unbolt the shock mount? I don't see how they'll go back in without that.
Thanks!
Mark
Thanks!
Mark
Me too. If your heads are clean re-surfacing the manifolds should take care of your leaks.
Yeah, but my fender liners are already on the garage floor...
Any tips from those of you who did remove them for this job?
The heads look good, but have soot and that sort of thing on the mounting surfaces. Should I hit them with a surface prep wheel to clean them up
What's the right anti-seize for the bolts? I'm assuming the regular stuff won't handle the heat well enough.
Mark
Any tips from those of you who did remove them for this job?The heads look good, but have soot and that sort of thing on the mounting surfaces. Should I hit them with a surface prep wheel to clean them up
Mark
I would recommend using new bolts and I don't use any type of anti-sieze.
I also would suggest leaving the head surface alone as you might create more of a problem.
On the anti-seize, I decided to try the purple caliper pin grease, which states it has close to a 3k degree drop point, it's been over a month now, and it is still purple and greasy. All I'm concerned with is protecting the threads from rust... I had a heck of a time getting my passenger side manifold off.
On the fender liners, if your shock mounts are installed, you need to cant the fender liner toward the outside of the truck so the liner will clear the top of the shock, then sneak the outer edge under the fender.
, I don't worry about the bolts rusting much. I had no trouble getting mine out.Mark
On this note, I believe I have a leaking exhaust manifold on the driver's side as well. How big of a battle is it going to be removing the stinkin' things... busted bolts, stripped bolts, etc. Should I just go buy 5 gallons of penetrating oil and pour it on the motor?
Just did the manifolds on mine the other day. Ended up cutting all the bolts off just behind the manifold and using heat and a vicegrip for removal of the remainder of the bolts from the heads. Of course, the engine was on a stand and not in the truck. The bolts were all siezed in the manifolds, took some more heat and an air hammer to remove them. They were all coated with antisieze especially the part that passes through the manifold, before being installed. We just used regular gray antsieze. If I had some, we would have used the copper stuff.
Mdc9966
Oct 15, 2015 05:48 AM
JLuskin
Aug 26, 2015 12:18 PM
bluesky636
Nov 28, 2004 03:27 PM
