injector replacement parts needed?
Old Jun 24, 2011 | 05:27 AM
embry1123's Avatar
embry1123
The injectors have arrived, I also bought a valve cover gasket and a slew of o-rings for the fitting on the oil rail supply line. I will be doing this work tomorrow and the dealer is closed on saturdays, what other parts if any should i have on hand? Already have oil change parts as well as new fuel filters on hand. Also, on an 03 is the oil supply line an stc fitting? If so, what is the method for disconnecting it? Can it be done without special tools?
Thanks-
Old Jun 24, 2011 | 05:38 AM
Maxium4x4's Avatar
Maxium4x4
A buddy to cheer you on, band aids and no children within a 500 feet radius of the work area.
Old Jun 24, 2011 | 05:56 AM
zhilton's Avatar
zhilton
When I replaced the four odd numbered ones on my truck last summer, we reused the valve cover gasket; 20k miles later no oil leak. I'm pretty sure you can reuse them (they're made of rubber). The bottom two valve cover bolts by the a/c box will be a pain in the butt. To disconnect the oil rail, one of those really thin die grinder wrenches to be the best tool...it'll have a big enough opening to get to both sides of the quick-connect fitting to release it. If no one has brought this up...once you get it back together; it will take it a while to fire off once you start cranking on it. You've got to re-fill those oil rails with the HPOP before the sticks will shoot fuel into the cylinders.
Originally Posted by Maxium4x4
...band aids and no children within a 500 feet radius of the work area.
embry1123's Avatar
embry1123
I hear that! Thanks John
Jeff-
npccpartsman's Avatar
npccpartsman
You can use a die grinder wrench to disconnect the oil line at the HPO rail. You shouldn't need the valve cover gasket as the factory are reusable. You'll need something like q-tips to clean out the oil in the injector hold down bolt holes. 12mm deep socket and flex head gear wrench, 10mm flexhead gear wrench. 11mm or 7/16" deep socket. FWIW--if you can't get the oil rail STC fitting to disconnect you can use a thin flat open end wrench and screw it out of the rail and leave the flex line in place. Call me if you have questions, but you should breeze right through. One other thing you might want to do........when you get all the sticks out disable the fuel pump and crank the motor a couple of times to squirt the fuel out of the cylinders. Be sure you cover the head with a towel and weigh it down or you'll have a diesel geyser.
DON"T OVERTORQUE THE VALVE COVER HOLD DOWN BOLTS. They really don't take much and easy to strip.
Old Jun 24, 2011 | 05:58 AM
embry1123's Avatar
embry1123
Excellent info zhilton, thanks!
Old Jun 24, 2011 | 06:01 AM
embry1123's Avatar
embry1123
Hey TIM, thanks for chiming in. Flex head gear wrench?
Old Jun 24, 2011 | 06:04 AM
embry1123's Avatar
embry1123
I haven't been able to locate your number from the last time we talked, can you IM it to me?
npccpartsman
If you don't have them don't get them just for this, but they sure make working on a 6.0 a LOT easier. I use the 12mm flexhead and a lot of patience for the back two valve cover bolts by the HVAC box.
If you do decide to invest in a set get the ones that are twisted 90*. Sears has them. You'll need 8mm - 19mm and IIRC all comes in a set for about $100, maybe less.
Old Jun 24, 2011 | 06:06 AM
npccpartsman
on the way
Old Jun 24, 2011 | 06:11 AM
embry1123's Avatar
embry1123
Thanks, ill call if I get stuck on anything. I appreciate your willingness to help and your knowledge of these machines!
Jeff-
Old Jun 24, 2011 | 06:18 AM
bismic's Avatar
bismic
Jeff-
Don't we all!! Tim is always willing to help!
Old Jun 25, 2011 | 05:29 AM
Maxium4x4's Avatar
Maxium4x4
I have Tim on speed dial..... Keep us updated on the progress Jeff.
Old Jun 25, 2011 | 06:28 AM
embry1123's Avatar
embry1123
Will do. First, coffee with the wifey, then on go the old jeans and t-shirt! I'll let ya know how it goes.
Old Jun 25, 2011 | 03:32 PM
embry1123's Avatar
embry1123
Well, she's all back together and running like a champ again! My sincere thanks go out to all. I took pictures at various stages during dis-assembly and will post them a little later on. Now its time to clean up. Tomorrow I will be installing the new blue fuel spring kit, it came in the mail today from partsguyed. life is definitely good again!
