First time posting here and have a question about the steering issue with my truck.fficeffice" /><O></O> <O></O> I have an 04 f350 CC with the fx4 and the 6.0l with 215000 miles. The truck wants to wonder all over the road you have to keep turning the wheel to keep the truck in the lane. I have changed all the ball joints replaced the draglink and the steering box (was leaking). When I took it in for the alignment the tech said the thrust angle was out of spec. <O></O> <O> </O> If I remember correct he stated that it should be .25 and I was +.32. What do I need to look at to fix this? According to the tech everything else looked good under the front he just did not know what to do to fix the thrust angle.<O></O> <O></O> Any help would be appreciated
Thrust angle meeds your rear axle is slightly out of square with the vehicle. To fix, you need to loosen the rear u-bolts and fudge one side forward and one side back, depending on which way it's off. Thrust angle won't cause a wandering issue though, it will just make your truck look like it's dog-tracking a little and that small number won't hurt anything. Better to not loosen the u-bolts if possible.
Thanks for the reply's. I will leave the axle alone and the gearbox was purchased from a local auto parts store as the original dumped fluid all over my driveway.
I do not remember. When I went to have the aligment done the tech found the thrust angle off and said he could not do the aligment. Do I need to take it to a differnent shop?
The spec is -0.25 to +0.25 degrees. Being 0.32 degrees off zero really isn't that much still, that makes the centerline of the rear axle hit the front axle about 3/4" off center, so you would get about that much dog-track. It works out to one side of the rear axle being less than 1/4" too far forward or back.
Has the truck ever been in an accident? My thrust angle was off about that much due to frame damage and one rail being pushed back slightly. They still aligned the front axle to the existing thrust angle and it drove great.
I would find out what your castor and toe numbers are, those will have more influence on wandering. Also, check if your new steering gear has slop in it. With key on to unlock steering and engine off, see how much steering wheel movement you get with low force so the tires aren't turning.
The OP said his drag link was replaced. But what about the tie rod and ends?
In addition, thrust angle in a leaf sprung vehicle could be from one side's springs settled more than the other side. This would cause the lower side of the rear axle to be slightly further back, because as the spring flattens, the shackle moves backward, slightly moving the rear axle backward with it.
I've had many ford trucks (60's 70's 80's) and Many of them have had thrust angle issues. When following a ford truck down the road I often look down the side to see if it's dog legging down the road and the drivers side e-brake cable hangin down at the rear axle just waiting to snag a stump or something. Like Cartmanea said above, it shouldn't be a problem to align it. After the work you have done so-far it would be necessary.
Ther was an interesting post here a couple of weeks ago concerning a similar issue. The OP's truck was 4wd and it turned out to be binding at the u-joints on the front drive shafts. From what was posted the only grease zerks on the front of his truck were on these u-joints. After greasing them a couple of times and driving it a few miles the steering issue cleared up. A little off the wall I know but maybe worth a shot.
U-joints shouldn't be an issue if not in 4wd though.
Hate to disagree with you, but I do.
I just had a u-joint failure (seized) on my truck and trying to keep it on the road at times was a chore. It felt like the front end would "float" from one side to another. I could feel a pulsation through the steering wheel. At times, when I made a corner, it would not return to center. If I yanked it back it would return to center...sort of. I t would pull to one side and if I pulled it back, it would pull the opposite direction. On occasion it would flop from one side to another driving down the street. I had to come to a complete stop, pop it into neutral, idle the engine up and turn the wheel from lock to lock to get it to straighten out.
