i was wondering if u could take a 2001 intercooler and put it on a 97 mine currently does not have a intercooler and i just got back from sc where a man and a bunch of 7.3 parts for sale on craiglist and i picked up the intercooler and pipes and turbo for a 100? did not know if any of this stuff would work on mine but was not leaving it behind if u know what i meen so if anybody has any info on this would much appericate it thanks
it can work. you just gotta pipe it in. i have a 6.0 on my idi. after i mounted it all up, went to the exhaust shop and had him bend all my tubes up. took a little bit of work and routing but it worked great. you are going to lose overall boost pressure since your trying to fill a ton more volume but its going to be a denser charge so thats helpful. it will lower your egt's too. just heat wrap and ceramic spray your exhaust manifolds and up-pipes for maximum spooling on your turbo. keeping the heat in will help tons.
sweet thanks was wondering that going to strat that in the am then want it on for the next trip do u know if it will help my milage any? (oreocreaming by the way love the truck plan on putting mine up there soon as i dont have to work out of it )
mmmm.... i didnt get any better mpg but i didnt have the right gears in with it. my turbo is out now that i got the right gears in to make room for the 02 psd turbo. and thanks.... ive got a lotta work into this girl. i smile every time i walk outta my front door and see her..... and i use my girl to work all the time. shes never without a 1 or 2 car trailer behind her butt unless im using it at my construction job for her onboard air. twin 4cfm 200 psi 100% duty compressors.
sweet dont think i could hook my goose neck in the back at that tall looking for a dullay to haul with i do alot of state to state hauling i sent u a message about ur shakle kits to ur profile and the air horn r well needed i will have some when i get that big
