the restore product that everyone talks about? I just did a flush with the vc-9 but no one in this area ever heard of the restore product. The dealer tech, an independent auto/truck repair facility, NAPA!
I need to maybe try to run it if I can find it, I tried a search for it but ended up with a site in england for it. As it is right now I am at the point where I need to plan to R&R the sytem but $7500 for the BPD sytem and studs is a lot of $$ if I can get improvements with this stuff.
am running a coolant filter, did find some sand not alot, had a trace of goo from a leak at the filter connection. With the VC 9 the coolant temp dropped and opened the delta on the eot, so I think maybe I need to try to flush with this stuff if I can locate someplace locally or.....?
You want to use Restore first (alkaline cleaner to remove sludge) then Restore Plus or VC-9 (acidic cleaner to remove rust and prep metal for new coolant).
