Leaking fluid power steering I think
Old Jun 21, 2011 | 11:43 AM
aero993's Avatar
aero993
While parking my boat in my yard. I had to continually pull forward and back up while cutting the wheel hard. To place my boat on the edge of my drive way. My Excursion 02 4x4 diesel starts leaking a lotof what appeared to be power steering fluid . I had just had rotator cuff surgery, so I couldn't look to see the source. My power steering resevoir appears to be low. All hoses appear to be attached. I have only moved the truck once since this occurred. Any ideas as to what caused this. The truck has a red head steering box.
Thanks
Old Jul 5, 2011 | 05:17 PM
So-Cal's Avatar
So-Cal
The pressure side of the pump has a hose that pops out when it stops working. Once this happens, you need to replace the entire line. If you pop it back it, it will simply come out again... When you take the air box out and see the problem clearly, it looks like a simple o ring will fix it, but it wont. You need to replace the high pressure line, probably the line going to the booster...Ford wanted 89.00 for the hose...autozone was only 28.00...Hope that is the problem, it was an easy fix for me...Bummer you can't just put an o ring in...
portsample
Apr 9, 2020 09:32 AM
1992FordF150Custom
Jul 6, 2014 03:31 PM
AceofExcursions
Mar 11, 2014 05:24 PM
BillHughes
Escape & Escape Hybrid
Dec 26, 2013 09:59 AM
superduty4x4
40
Apr 26, 2011 09:49 AM
