Cab Removal Question
Old Jun 21, 2011 | 07:31 AM
abealex's Avatar
abealex
Hi all-
It's my turn to do head gaskets and all of the other related fixes/mods.
Has anyone ever lifted the cab off with an overhead hoist?
I have a shop with a hoist strong enough and high enough to do it,
but don't know how to attach it safely without doing any body damage.
Has anyone done this, or have any ideas on how?
Thanks, Ed
Old Jun 21, 2011 | 08:37 AM
cartmanea's Avatar
cartmanea
I'll be removing my damaged cab with a knuckle boom, but not going to use it to put the good one on. Not saying it can't be done, but not wanting to try it.
Old Jun 21, 2011 | 06:15 PM
cheezit's Avatar
cheezit
keep in mind a loaded 4 dr cab weighs somewere near a 1000 lbs
Old Jun 21, 2011 | 06:46 PM
cartmanea's Avatar
cartmanea
Good to be safe. Our knuckle boom will lift 1500 lbs at full extension, which we won't be anywhere near. At the needed reach it will lift about 3000 lbs.
OP, what is the capacity of your overhead hoist?
Old Jun 22, 2011 | 12:59 PM
abealex's Avatar
abealex
The hoist is a 2 ton. It's a trolly type - rides overhead I-beams. I was not concerned with the capacity - I didn't want to do body damage if I put a brace through the cab (ext. cab). We were going to place a beam just under where the latches are for the rear 1/2 doors, and a strap to the engine area. I guess my question is would the body support itself being lifted that way?
Old Jun 22, 2011 | 02:18 PM
jbenford's Avatar
jbenford
i have lifted two cab's with a fork life. one was a 4dr the other an ext cab. unfortuately both got some damage to the roof. we used straps with no beam. I am about to do another and am wondering the same thing as you. what is the best way to run a strap or beam to not have any damage. the cab can hold it just fine. but i got a couple little wrinkles where the straps were.
I'll be watching the thread to see a great answer.
Thanks guys
Old Jun 22, 2011 | 02:41 PM
cartmanea's Avatar
cartmanea
I would get some heavy pipe or tubing and run it under the cab on each side, near where the running boards attach and where the lifting points are, then use a strap on each side connected to the pipe ends. That way the weight is supported by the floor pan and not the roof. This would require having the fenders off though.
Old Jun 22, 2011 | 05:04 PM
cheezit's Avatar
cheezit
being thats its basicly a chain fall you want to use its not gonna be easy.
I think I may try to weld a frame together that bolts to the bottom of the cab or slides under it and find a good lift point.
If it were me I would just pull the enigne.
Old Jun 22, 2011 | 06:01 PM
cartmanea's Avatar
cartmanea
For heads, I would just do them with the cab on. Maybe jack up the cab a few inches to give more clearance, but I would definitely not pull it. In my case, the cab is crunched and being replaced...
Old Jun 22, 2011 | 07:10 PM
jbenford's Avatar
jbenford
the ford pdf in the tech folder for doing head gaskets with cab on says nothing about removing the a/c box on the passenger side. is it nessesary to remove that? if so, how hard is it.
Old Jun 22, 2011 | 07:15 PM
cartmanea's Avatar
cartmanea
Replacing the #5 injector was very tight with the HVAC box in place, I can't imagine doing head studs without removing it.
Old Jun 22, 2011 | 11:21 PM
rdunagan's Avatar
rdunagan
yea me either it would have to be removed. i know tyler (06powerstroke90) removed his box and made it much easier
Old Jun 23, 2011 | 08:04 PM
cheezit's Avatar
cheezit
none of the injectors are really hard to get out its all in having the right tools.
Old Jun 23, 2011 | 08:13 PM
2006powerstroke90's Avatar
2006powerstroke90
I dont see how anyone could do studs with that box in the way.
With it out of the way, man was I happy.
cartmanea's Avatar
cartmanea
I had no trouble getting it out, it was getting the torque wrench in there when installing the new one that was tough.
Also, we don't all have the tool assortment you have
paulwjax
Aug 17, 2013 05:42 PM
the_auto_tech
Oct 16, 2012 09:44 PM
john11139
Apr 22, 2011 05:37 PM
BlueOvalBud
Aug 15, 2010 10:24 PM
shoe
Jul 11, 2001 07:30 AM
