E4OD solenoid problem??
Old Jun 20, 2011 | 12:14 AM
bob69302's Avatar
bob69302
Question E4OD solenoid problem??
Hello,
I am working on a 95 f-350 7.5L E4OD. The truck has had a lurching problem for years now and no ford dealership has been able to fix it. I was reading today that a bad solenoid pack can cause this problem (TC lockup solenoid), so i went out and disconnected the 9 pin connector today, started the truck and put it in reverse and the truck didnt miss a beat. I pulled the pan and the solenoid pack and it checked good at 20.4 Ohms for each coil. All the pins look good on the pack and the wiring harness. I am wondering if the pack is really the problem by shorting out for a split second causing the lurching or maybe the solenoid bleeding some pressure. I hate to spend the couple hundred on a pack and not have this fixed!
I think I am finally on to the problem because when the pack is disconnected it runs perfect.
Any ideas?
Thanks
Phil
Old Jun 20, 2011 | 07:16 AM
Edgethis's Avatar
Edgethis
Hmm. Doesn't tha just tell the TC when to lock and unlock tho? Maybe its a bad TC? since its not locking or unlocking it rides smooth.
FORDF250HDXLT
21
Mar 16, 2026 09:43 AM
7threeaz
Jan 7, 2019 06:32 PM
velcro7279
Sep 8, 2016 12:52 PM
CodyAustin
Sep 1, 2016 09:04 AM
RIKIL
27
Jun 29, 2016 04:44 PM
