f6
Old Jun 19, 2011 | 04:05 PM
big red0308's Avatar
big red0308
f6
i have a f6 ton truck im trying to make it a pickup truck do i have to take off the fenders wat do yall suggest
Old Jun 19, 2011 | 04:33 PM
harleymsn's Avatar
harleymsn
First, an F6 is a 2 Ton truck. The best advise I can give you is that IF you want a pickup, get an F1 or F2 to start with. otherwise, take off the cab and hood and slide a pickup under it.
Old Jun 19, 2011 | 09:48 PM
HT32BSX115's Avatar
HT32BSX115
Yeah.....the front fenders are going to look ALL WRONG if you use them too.
They have HUGE wheel cutouts.....
Old Jun 19, 2011 | 11:18 PM
bobj49f2's Avatar
bobj49f2
The F-6 fenders are the same as the F-2s, the F-1s have the smaller wheel opening. The F-2 to F-6 will work on the F-1, the wheel openings will be slightly larger. My neighbor has a '51 F-1 with F-2 fenders and I never noticed it until a couple of years ago when he mentioned he had the F-2 fenders. He has larger wheels so they're not as noticeable.
Old Jun 20, 2011 | 02:07 AM
HT32BSX115's Avatar
HT32BSX115
I guess they're bigger on my F-600.....
Old Jun 20, 2011 | 08:31 AM
mtflat's Avatar
mtflat
53 thru 56 squared up the opening a bit making the hole appear much bigger.
I run F3 fenders on my 48 F1 and with LT215/85R/16's it looks acceptable. Using small 15's would look funny.
Talk to Stephen in Wyoming - he did the same project with his gen 2 truck.
bigdually3
401, 477, & 534 SD Engines
Jan 8, 2017 10:32 AM
Zero-Grav
Feb 4, 2014 04:13 AM
f1ford48
May 2, 2013 06:18 PM
CrzHelm
Dec 3, 2010 07:36 PM
BOB01
17
Feb 23, 2000 01:47 AM
