Lacking low end power...
Old Jun 19, 2011 | 04:40 PM
2006powerstroke90's Avatar
2006powerstroke90
So this has been going on for a while...but started getting worse.
I checked my up pipe/y pipe for leaks tried to tighten down the up pipe bolts to the manifolds but they were tight.
I still hear air hissing from somewhere. Really noticeable when I'm cranking the truck over.
Is it possibly my exhaust manifolds leaking?
I remember when I had my driver side head off I noticed a little black soot around cylinder #8. So could it be my problem is getting worse?
I'm still building 30lbs of boost at wot.
Any ideas thanks.
Old Jun 19, 2011 | 04:52 PM
1bad04's Avatar
1bad04
Im having the same problem with my 04. Noticed a few cylinders leaking black soot at the manifolds. Truck doesnt seem to be boosting right and done on bottom end power. Does your engine/turbo/exhaust sound any quieter then normal? mine is very quiet. So now im wondering the same thing.
Old Jun 19, 2011 | 06:57 PM
cheezit's Avatar
cheezit
best way to find a leak is with a smoke tester. not something most people have laying around.
Old Jun 19, 2011 | 07:05 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Sounds like a great reason to smoke a good cigar!!
Old Jun 19, 2011 | 07:06 PM
cheezit's Avatar
cheezit
is the embargo still in effect?
Old Jun 19, 2011 | 07:38 PM
rdunagan's Avatar
rdunagan
did you put exhaust manafold gaskets on when you did the heads? i know they arent needed but i did on mine and my brothers just so i wouldnt have to worry about it
Old Jun 19, 2011 | 07:44 PM
2006powerstroke90
No I didn't but believe me if it needs them I'll be kicking myself for not doing it then.
What causes the manifolds to leak?
Old Jun 19, 2011 | 07:49 PM
rdunagan's Avatar
rdunagan
bolts not tight enough, warping, holes. things like that. get the torque specs though. you wouldnt wanna break wanna those off
