F350 Tioga Motorhome Engine WONT start
My engine wont start. It always had to turn over a bit and have the pedal pushed when starting to fire up. Worked consistently but after a few months of sitting it wont start. Tried jumping, swapping batteries, and messing with the inertia switch. When i go to start the engine it clicks and turns but doesnt sound liek its getting any fueld and then the power fades. Help?
And what year?
Take the air cleaner off and open the throttle with your hand as you look down the throat of the carb, you should see two strong streams of gasoline being injected.
BTW the Owner's Manual says to not run the starter motor for more than 45 seconds straight without letting it cool down.
A friend of mine burned out his starter by trying to jump-start it while it had a frozen fuel line.
mikels
17
07-21-2021 12:08 AM
billenglish61
1999 to 2016 Super Duty
11-22-2015 01:45 PM
jerryparks
08-22-2015 07:00 PM
