79 F150 problems
Old Jun 18, 2011 | 09:16 PM
JDB830's Avatar
JDB830
79 F150 problems
Got an old ford F150 1979 4X4. With the 300 six, The truck only runs with the key in the start position.. I have figured out that by putting an adjustable wrench on the key its enough weight to keep it in the start position. then I can bump the starter wire to the battery and shes purring like a kitten, let the key go back to the run position and its just like shutting it off. Ive replaced the switch, the computer module on the inside of the left fender and no change, I've check fuses ran wires but I'm not finding the cause. any of you guys got any ideas?? thanks
Old Jun 19, 2011 | 01:44 AM
Riderman's Avatar
Riderman
Originally Posted by JDB830
:- Ive replaced the switch, the computer module on the inside of the left fender and no change, I've check fuses ran wires but I'm not finding the cause. any of you guys got any ideas?? thanks
We have a saying at work, show me where you have been, I'll show you the problem. When the switch is in the start position, you should have voltage to the S terminal of the solenoid. That should turn the engine over. Get that working, and we will walk you through the rest of your issue. If your not getting the voltage to little terminal on the solenoid, we will start there. Believe it or not, electricle issues are not to hard to figure out.
Old Jun 19, 2011 | 09:39 AM
devino246's Avatar
devino246
If you dont already have one, get a test light. They're essential for things like this.
87 f250
May 12, 2013 07:57 AM
joshts6262
17
Feb 26, 2013 09:09 PM
73FOMO
Dec 6, 2010 11:23 AM
ken2400
May 8, 2010 12:03 AM
Mr Ed
Electrical Systems/Wiring
Jan 22, 2003 11:06 PM
