12V + Run Ignition Source
Old Dec 6, 2010 | 10:56 AM
73FOMO's Avatar
73FOMO
Anyone know of a good 12v + Ignititon Source with key in run only position on the right side of motor with 302. Prefer not to run wires across engine bay if I can help it. Need to make a connection around the battery area. The solenoid trigger is only hot when key is in start...and of course there are plenty of other constant 12 v sources near the battery. Any help would be appreciated. 1995 F150 4x2.
Old Dec 6, 2010 | 11:17 AM
1966Tbird's Avatar
1966Tbird
i beleive there is a switched wire running off of the alternator that you could use
Old Dec 6, 2010 | 11:23 AM
73FOMO's Avatar
73FOMO
I was thinking that too... I checked a yellow colored one and it showed 12v with key off, and I check the green/red wire and it was showing like 2.6 volts, but I was swearing there was one there that was hot only in run.
xaviar
Sep 22, 2021 02:01 PM
karljay
Dec 17, 2015 03:48 PM
Ted Bell
Oct 10, 2014 10:25 AM
Turbo Dog
Aug 2, 2014 10:48 PM
NMFirstF2504X4
Mar 14, 2014 08:02 PM
