Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
HF stuff update
Old Aug 10, 2012 | 04:51 AM
taycotrains's Avatar
taycotrains
I like there rechargeable 8.9 volt batteries....I have 54 modern era o gauge locomotives that use these as backup system for the electronics.
The OEM battery is over 12.00 dollars the HF battery is 2.99 and just as good if not better !
BT
Old Aug 10, 2012 | 01:20 PM
oldcoupe42's Avatar
oldcoupe42
I've had great luck with HF hand tools and air tools. Was going to get the cordless sawzall for an exhause job because of the nice "swivel head" feature, but may go for the codered model after reading the poor reviews.
I've sean 2 of the cheapo $69.99 chop saws fail, but they were being used hard for production work. Anyone have any futher experiences with the cordless sawzall or the more expensive $99 metal chop saw?
Chet
Old Aug 16, 2012 | 09:34 PM
cigarxtc's Avatar
cigarxtc
I've checked the reviews and watched some youtube vids on the yellow motorcycle lift. I took the plunge and ordered one today. I'll post a review on it later.
Old Aug 19, 2012 | 08:01 PM
Ford_Six's Avatar
Ford_Six
If you are going to use the sawzall mostly on sheet metal and exhaust, get a real one. Thin stuff grabs the blade and that is really hard on the gears. I destroyed a couple B&D Firestorm ones like that.
Old Aug 20, 2012 | 02:08 AM
muscletruck7379's Avatar
muscletruck7379
I have used my HF sawzall on alot of exhaust, not so much sheet metal though, for about 4 years now without any problems. its also the same sawzall that went through an 80's f250's frame in under 4 minutes.
I do however use good blades.
Old Aug 20, 2012 | 09:01 PM
*2fords*'s Avatar
*2fords*
I can say without a doubt HF sawzall blades ain't worth a crap. The bi metal blades don't last long cutting any ferris metals.. The wood blades last pretty decent amount of time as long as wood, sheet rock and other soft materials is all you're cutting. Touch a nail with them, just throw the blade away.
HEAVY100
80
Nov 17, 2019 01:07 AM
andyort
Engine Swaps
30
Mar 5, 2017 03:53 PM
ATG_Tuning
Dec 5, 2015 08:48 PM
Plowingking
Oct 4, 2015 03:35 PM
