Bronco II Ford Bronco II
Fuel Pump
Old Jun 18, 2011 | 07:06 PM
Revmitchell's Avatar
Revmitchell
Fuel Pump
Is the fuel pump in the gas tank?
Old Jun 18, 2011 | 10:19 PM
mrshorty's Avatar
mrshorty
What year?
I don't know about the '84/'85 2.8 L engine.
The '86 and '87 (and maybe some '88's) had two pumps: a low pressure "lift pump" inside the gas tank feeding a high pressure pump on mounted to the frame rail.
'88 on up used a single high pressure pump in the gas tank.
Old Jun 19, 2011 | 08:25 AM
Revmitchell
I'm sorry it is an 87 2.9 L
Old Jun 19, 2011 | 02:25 PM
mrshorty's Avatar
mrshorty
Then, assuming it's still the factory set up, you have two pumps: low pressure in the tank and an in line high pressure pump on the driver's frame rail.
luv2ski
Apr 3, 2013 12:01 PM
bassproguy07
Aug 20, 2006 09:13 AM
shazam
Feb 15, 2002 12:12 AM
redbronco2
Bronco II
Mar 22, 2001 11:58 PM
proeliator
Jan 1, 2001 03:29 PM
