White smoke...HELP
Old Jun 19, 2011 | 09:45 AM
timmyboy76's Avatar
timmyboy76
MAT sensor
Apologize to Admin, hate posting other "forums", but think its a good "thread"...
IF your 7.3 starts blowing white smoke, and stumbling - READ THIS - MAT SENSOR - Ford Powerstroke Diesel Forum
Old Jun 19, 2011 | 10:53 AM
Pitcrw6's Avatar
Pitcrw6
Thanks im headed out now too try this.
Old Jun 19, 2011 | 11:01 AM
timmyboy76's Avatar
timmyboy76
ebay
Got that sensor on my "watch list"...
NEW DELPHI FORD E SUPER DUTY TEMPERATURE SENSOR TS10098 | eBay
Old Jun 19, 2011 | 12:41 PM
EMD_DRIVER's Avatar
EMD_DRIVER
I don't know if it's allowed or not, but I learned something from that post! I didn't even know that sensor was there! I'm hoping it'll be the solution to my problem!
BTW: Reps sent to you!
Old Jun 19, 2011 | 02:57 PM
ToMang07's Avatar
ToMang07
Great Find! I knew about the sensor.... DIDN'T know it could cause those problems! Reps your way!
I asked the mods on PowerStroke(dot)org to move it to the tech files under repair help, too! Hopefully save someone else some headache one day!
Old Jun 19, 2011 | 03:26 PM
hotroddsl's Avatar
hotroddsl
Great info I have never run across a failure on MAT sensor but I will be adding it to my crazy mixed-up brain reps indeed!
Old Jun 20, 2011 | 09:12 AM
Pitcrw6's Avatar
Pitcrw6
Well heres an update: I guess somethings are not meant to make sense.
-I checked the coolant and no oil or diesel in it but added a gal of distilled water
-checked the fuel filter and it was good
-re-tightened all the boot clamps
-looked all around the trubo for oil leaks and dry as a bone
-ckecked the oil in the HPOP and it was about an inch low so I added oil to bring it back up to 1/2 inch from the bottom of the plug
-no frothy oil on the dipstick
-I pulled my chip out and then cranked it up and just a little puff of white smoke came out which is normal when the eng is cool and sitting over night
-took it for a ride and no white smoke and no power loss at all
So it was either 2 things the oil in the HPOP low or my chip. I didnt think the oil being low in the HPOP would cause it but I could be wrongand someone please tell if im wrong. Im thinking more towards my chip. I didnt put it back in and will drive it around a couple days to see how it drives and if its running fine then I will drive it back to SC and then put the chip back in and see how it runs then. The only thing I didnt ck was for blowby which im headed out there now to ck. I didnt know what the MAP sensor did but I do now I didnt try that because it was running fine after I took it for a ride.
Old Jun 20, 2011 | 11:31 PM
Pitcrw6's Avatar
Pitcrw6
Well I checked for blow by and the oil cap just sat there. I drove it aroud town all day and not one bit of problems. Just hope it does that when I drive home on thursday. Thanks everyone for chimming in and tell me what too ck.
Melendez7.3
16
Oct 23, 2015 12:26 PM
johnzenobia
2009 - 2014 F150
Aug 28, 2015 07:30 AM
Razor Back Bowhunter
Dec 18, 2011 07:33 PM
millerfordidi
Nov 23, 2011 12:55 PM
rkbutz55
Jan 14, 2011 01:13 AM
