Removing 351W engine?
Old Mar 26, 2003 | 10:44 PM
mdentzien's Avatar
mdentzien
Question Removing 351W engine?
This may sound stupid, but I'm trying to locate the "lifting brackets" on my 5.8L engine from a 1988 F150. This is where you are supposed to attach the sling or chain to. Can anyone help?
Old Mar 26, 2003 | 10:59 PM
goofin's Avatar
goofin
they should be near exhaust manifolds, if not maybe they were removed
Old Mar 27, 2003 | 02:02 AM
dpbrowne's Avatar
dpbrowne
I just put an engine in my 1987 F150. There were no brackets but on the top of the manifold there were two attach #8 bolts (hardened steel). One was on the front right and the other on the back left. I bought 2 feet of heavy chain put the bolts through the links screwed in the bolts and attached the hook of the hoist to the chain. Using extra chain gave me a little more mobility movong the motor around. Make sure you use hardened bolts and a heavy chain. That is how I did it and it worked well.
Old Mar 27, 2003 | 08:30 AM
mdentzien's Avatar
mdentzien
thanks guys, I should be removing the engine today. I'll let you know how it goes.
Old Mar 27, 2003 | 09:33 PM
steve83's Avatar
steve83
My '96 parts truck has one eye on the front of the L head, and from the layout of the engine, I think the other lift point is the support bar that runs from the R ex.man. to the plenum.
dadstruck
16
Feb 23, 2025 06:53 AM
jowilker
Nov 10, 2012 10:43 AM
May 3, 2002 01:31 AM
Flash
1997 - 2003 F150
Mar 24, 2002 10:12 PM
RRL78
1978 - 1996 Big Bronco
Oct 17, 2000 12:10 PM
