Head stud question
Old Jun 17, 2011 | 02:04 PM
mustang9701's Avatar
mustang9701
Head stud question
I have read on here but cannot seem to find where that the assebly lube with the head studs isnt that great and to use something else, what are my options to get at local auto parts stores? and i also believe there was a debate on the correct torque specs? any help is appreciated
Old Jun 17, 2011 | 02:08 PM
BLADE35's Avatar
BLADE35
I think this is the new torque spec
https://www.ford-trucks.com/forums/a...7&d=1301182939
Id go to the ft/lbs that recomended on the headstuds
Iv only heard to use the lube the headstuds comes with IDK
Old Jun 17, 2011 | 02:15 PM
texans's Avatar
texans
You should use the lube the headstuds come with. That is the only way you will know what spec to go with on torque. If you use the new ARP molly lube the finnal torque is 210 if its the old lube it's 240
Old Jun 17, 2011 | 02:47 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Damn that is a bit of difference between two lubes
Old Jun 17, 2011 | 03:38 PM
mah77's Avatar
mah77
Always use lube!
Old Jun 17, 2011 | 04:46 PM
texans's Avatar
texans
Yes sir it is! I wish I had the new lube when I did mine. That 240 was a mother to pull!!
Old Jun 17, 2011 | 05:13 PM
2006powerstroke90's Avatar
2006powerstroke90
I have always wondered why lube would change torque specs
Old Jun 17, 2011 | 05:18 PM
william_04_x's Avatar
william_04_x
Different lubes will change the amount of frictional resistance, while still maintaining the desired amount of bolt stretch.
LRSTony
Nov 3, 2010 06:56 PM
shad9876
Oct 1, 2010 04:12 PM
jacob_powerhouse
Sep 10, 2010 02:00 PM
natem8301
Feb 27, 2009 04:00 PM
jmackie
Aug 7, 2003 07:12 AM
