6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
help truck wont start 08 6.4 diesel
Old Jun 16, 2011 | 07:00 PM
Jims 08 stroker's Avatar
Jims 08 stroker
I have a 08 250 6.4 I shut the truck off and went to restart it and it wouldn't turn over not even a click is there an fuse some where that may have blown thanks for any help Jim
Old Jun 16, 2011 | 07:09 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.4L Powerstroke Diesel forum.
Old Jun 16, 2011 | 07:48 PM
senix's Avatar
senix
Any guages work? Under what conditions did you shut it down?
Check your batteries?
Old Jun 16, 2011 | 09:06 PM
cheezit's Avatar
cheezit
make sure the truck is in park, set the e-brake, turn the key on
at the right side battery the is a 2" long or so black connector that is round. disconnect that and jump the male side it to the positive side of the battery. this may get you up and running.
Old Jun 20, 2011 | 09:21 PM
Jims 08 stroker
thanks for the reply I put the diagnostic programer on the truck and it showed a u0073 code I reset it and the truck strarted and ran fine the rest of the way to the track on the way home it did it again same code. Btw when it done it the 2nd time I was driving along and it started make loud noises and the truck starrted to run real crappy. From what I read its a bus communication error but I wonder what causes it . I have and H&S Mini Maxx and 4" downpipe back exuast. any info would be greatly appreicated and thanks again Jim
Old Jun 20, 2011 | 09:22 PM
cheezit's Avatar
cheezit
what module is the u0073 code referance.
Old Jun 20, 2011 | 09:24 PM
cheezit's Avatar
cheezit
none the less there are 2 common places I have found network issue to happen at.
under the dash there are 2 large connectors. check them both
the second spot is behind the air box. there is a flat connector not far away from the pcm.
Old Jun 20, 2011 | 09:28 PM
Jims 08 stroker
thanks cheezit I'll ck them tommarro
Old Aug 4, 2011 | 09:07 AM
Truck Paradise's Avatar
Truck Paradise
Any update? I'm in a similar situation with a 2010 6.4.
Btoddsmith
23
Mar 20, 2013 09:39 PM
OTTOMATIC
31
Oct 13, 2011 10:20 PM
jim922 trucks
Mar 31, 2008 07:01 PM
malojeer
Dec 16, 2007 10:34 PM
Thinkinfishin
Oct 26, 2007 07:30 PM
