engine mounts
Old Jun 15, 2011 | 10:08 PM
ritechous26's Avatar
ritechous26
engine mounts
How hard is it to change motor mounts. Got on busted on passenger side. Truck is 4x4 with 460 and c6 tyranny. I also have a chattering transfer case. I believe its a np 1345 and it leaks at the rear seal and the bearing has some play in it. I'll get the numbers off the case tag and post them tomorrow.
Old Jun 15, 2011 | 10:13 PM
Franklin2's Avatar
Franklin2
Cut a board that goes out to the edges of the oil pan. Take the bolts out of the mounts and jack the engine up using the board. Replace the mounts. Just make sure the board goes out to the edge of the oil pan. The vertical edge is very strong, but the flat part of the pan is weak.
btravis90
Feb 16, 2012 08:03 PM
DarrellJ
Dec 26, 2009 02:11 PM
66flareside
Mar 5, 2008 05:26 PM
dynamic
Jul 22, 2005 08:40 AM
DutchmanAZ
May 31, 2002 02:42 PM
