Delete
Old Jun 15, 2011 | 06:55 PM
DasCheckers's Avatar
DasCheckers
Delete
DeleteDeleteDelete
Old Jun 15, 2011 | 07:52 PM
427 fordman's Avatar
427 fordman
That powerstroke will probably outlast the truck so you'll have a hard time running it into the ground unless you ruin the truck at the same time. Then you won't be able to do your cummins swap.. No other comments if you're just looking to ruin a good powerstroke except find one with a bad motor.
Old Jun 15, 2011 | 08:31 PM
stainlessstroker95's Avatar
stainlessstroker95
ya were here to learn about and to fix powerstrokes not ruin them
Old Jun 15, 2011 | 09:44 PM
BuckHammer's Avatar
BuckHammer
Why would you WANT to run it into the ground? If you mean run the hell out of it, these engines will take a hell of a lot of abuse and beg for more. I think your best bet, like Darin said, is to find one with an already dead engine. With that, I can tell you that I've been looking for a truck with a dead motor and a working five speed, and I haven't had any luck at all. It seems like the only time these engines die is when the whole rest of the truck dies with it, from what I've seen.
Old Jun 15, 2011 | 09:56 PM
tshrager's Avatar
tshrager
I'm afraid you're not going to get a lot of advice on how to destroy and replace a stroke around these parts
Old Jun 17, 2011 | 01:06 AM
DasCheckers
DeleteDeleteDelete
Old Jun 17, 2011 | 01:38 AM
rockyrider's Avatar
rockyrider
The truck will fall out from under the triple 4 stoker. If it's one of our OBS your after just look for one without an engine.
Old Jun 17, 2011 | 01:53 AM
BuckHammer's Avatar
BuckHammer
You're better off getting a gasoline and swapping the engine out of that.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
