Injector identification
Old Jun 15, 2011 | 05:52 PM
85grey's Avatar
85grey
On top of the Injector that is closest to the fuel filter is a piece that the steel injector line connects to the injector. It is on the 7.3 and but not my 6.9. What is it and what does it Do?
Old Jun 15, 2011 | 06:18 PM
oreocreaming's Avatar
oreocreaming
thats for timing.
Old Jun 15, 2011 | 08:04 PM
85grey's Avatar
85grey
does anyone know why the 6.9 engines don't have them?
Old Jun 15, 2011 | 08:17 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
yes.
because the 6.9's were originally timed with a different style meter than the 7.3ls.
you would use a meter that used a luminosity prode,that screws into a glow plug hole on #1 or #4.
latter a different style meter came along that reads the pulse off the #1 injection line (this adapter your seeing is on #4 for vans.)
Old Jun 15, 2011 | 08:21 PM
85grey's Avatar
85grey
so the truck does not use it, it is used to set the timing?
Old Jun 15, 2011 | 08:33 PM
FORDF250HDXLT
that's right.
however if your actually trying to just ask;
can i remove the timing pulse adapter on my 7.3l engine will no ill effects.then the answer will be no,you cannot.
you need to maintain the correct length of this (and all) fuel line,otherwise your timing on #1 will be incorrect.this would mess up your ignition timing not due to what it is,but due to changing the length of the line if removed.
then of course you would be stuck with having to have the engine properly timed via the old school luminosity meter method.
so i think what your looking for,is should you try and connect the lines bypassing the thing because its leaking or something or replace it.
replace as need to avoid having an engine with a miss.
Old Jun 15, 2011 | 09:09 PM
85grey's Avatar
85grey
that seems pretty strait forward. I do have a leak there and wanted to ask you that actually would know what I was talking about so when I do go to get one I can explain it better. I am sure the parts guys will look at me and ask "well what is it or what does it do?"
Old Jun 15, 2011 | 09:10 PM
85grey's Avatar
85grey
thanks for the info
Old Jun 19, 2011 | 06:06 PM
85grey's Avatar
85grey
When I purchased the 7.3 two months ago I switched the IP and Injectors from the 6.9 I drove for 7 years because they were only about 6 months old. Did I need to replace the #1 hard injector lines to keep the lenght correct. The 7.3 has a very rough Idle only when warm. The 6.9 runs purrrrfect all the time. I know that I moved all the injector lines with the pumps. Then I can't remember if I switched the #1 line so that it fit better or not. The question is is the 7.3 line shorter to make up for timing pulse adapter?
Old Jun 19, 2011 | 07:46 PM
85grey's Avatar
85grey
I am not sure when the rough idle started. It may or may not have been when I did the IP
I think that it ran fine for awhile but I am not sure
Old Jun 19, 2011 | 11:18 PM
farmert's Avatar
farmert
The question is is the 7.3 line shorter to make up for timing pulse adapter?[/quote]
Yes the no. 1 line is shorter on the 7.3.
Old Jun 20, 2011 | 07:14 AM
85grey's Avatar
85grey
thanks farmert
tjc transport
May 15, 2015 08:24 AM
tjustice
Apr 21, 2015 05:44 AM
bill wilson
Sep 26, 2014 01:10 PM
TSFRD63
6.4L Power Stroke Diesel
Jul 9, 2012 01:32 PM
429 f-100
26
Aug 15, 2011 12:25 PM
