f150 HELP!
Old Jun 14, 2011 | 10:46 PM
ronixrider82's Avatar
ronixrider82
f150 HELP!
OK I am stumped and dont know what step to take next. I just filled it up with gas and went 17 miles then went to the store. Then put it in drive and it dies. SO I replaced the IAC that didnt work.. I unpluged the MAF sensor still did it. But it idles fine! And if you rev it up above 1500 rpms and put it into gear it wont die. Then if you let off the gas put it into park then back in reverse it wont die. Or drive. SO any suggestions onto checking next? Btw it is 4x2 with the 4.6
<!-- / message -->
Old Jun 17, 2011 | 06:19 AM
enriched&beyound's Avatar
enriched&beyound
<!-- / message -->
Have you run the codes to see what been tripped? next step
how does it run after you get it moving again? How many miles are on this?
could be many things....start simple.
change the fuel filter and check for vacuum leaks...& considering you just filled up...you might have gotten a bad tank of gas
benbo30
Mar 14, 2012 03:58 PM
cam4x4
32
Jul 31, 2011 08:56 PM
|WYG|SS
73
May 6, 2011 10:44 PM
spence340
20
Apr 14, 2011 10:41 PM
KPMariner05
Jul 25, 2007 05:38 PM
