spark plugs
Old Jun 16, 2011 | 08:39 PM
m2babbitt's Avatar
m2babbitt
spark plugs
when should i put in new ones ? we have 35,000 on it know
Old Jun 16, 2011 | 08:59 PM
tempforce's Avatar
tempforce
100,000 miles or thereabouts...
Old Jun 17, 2011 | 12:05 AM
phil6608's Avatar
phil6608
It depends on the year of the truck!
The 3V heads have problems with the plugs breaking off,so its better to change them early. Like 50 to 70K
Old Jun 17, 2011 | 12:10 AM
m2babbitt's Avatar
m2babbitt
it is a 2007
Old Jun 17, 2011 | 12:23 AM
phil6608's Avatar
phil6608
That has the 3 valve heads, but I think they fixed that problem by 07.
Check the TSB on 3V heads to be sure.
If I'm right,,,you should be good to 100K
Old Jun 17, 2011 | 12:33 AM
phil6608's Avatar
phil6608
I was wrong!
The TSB is for 04 to 08. Sorry.
https://www.ford-trucks.com/forums/7...g-removal.html
I would change them at about 50K if it was me.
Old Jun 17, 2011 | 06:42 AM
tempforce's Avatar
tempforce
be sure to use the copper anti-seize on the threads and the dual platinum tipped plugs.
Old Jun 18, 2011 | 12:13 PM
Aftrmidnite's Avatar
Aftrmidnite
After you pull the Coil Paks and boots, Blow out the plug wells with compressed air, loosen the plug a half to three quarters of a turn and blow out again. I'd replace the boots, dont forget to put Dielectric grease, on both ends of the coil boot springs and coil boots.
I did the right bank first starting at plug one, took the truck for a test drive. Took a break while I let everything cool, did the left bank. On plug 8 I used a 1/4" extension, with 3/8" adapters on both ends. You'll need a swivel, and electric tape is a must to hold the socket to the extensions, and extension to adapters. Only mishapt was a dropped a coil pak screw, and I couldn't find it. I Think it was under the intake manifold.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
