Transfer cases
Old Jun 13, 2011 | 11:53 PM
ADTMan's Avatar
ADTMan
Transfer cases
Can someone please educate the dumb indian over here? LOL Divorced, married, hell I have been divorced since 97! NP205?
The reason I am asking is because I understand that the NP205 is gear driven and bullet proof. So I need some education. I am assuming I want a divorced case because I am wanting a brownie between the tranny and the xfr. I have found an NP205 w/yokes for 300 out of a 78 ford. I just need to know the differences and what to look for. Hell someone just teach me! LOL
Old Jun 14, 2011 | 09:09 AM
farmert's Avatar
farmert
The 205 is a cast iron cased, gear driven transfer case, and as you said bullet proof. No chains to break. The devoriced case runs a short drive shaft between the transmission and the transfer case, while the married case is bolted right to the tranny. The devoriced case will have a yoke on the input shaft, while the married one will have a splined coupler on the input shaft. That one from the 78 ford will more than likely be a married case.
Old Jun 14, 2011 | 03:30 PM
ADTMan's Avatar
ADTMan
So in order to use a brownie, (gear vendor) in 4wd I have to have the brownie, "divorced" from the tranny, then divorced to the xfr right? So if that is a married xfr then I need to keep looking for a yoked, divorced 205. What is a NP203?
Old Jun 14, 2011 | 06:29 PM
farmert's Avatar
farmert
A 203 is a cast iron cased chain drive transfer case. I would say you are right on the tranny, brownie, transfer cas arrangement.
Old Jun 15, 2011 | 02:52 AM
ADTMan's Avatar
ADTMan
Man thanks so much. I so appreciate all the help on here. If I ever get this rig together it is going to be damn nice...LOL I hope...LOL I may be old and retired by then, but dammit I am going to have my truck they way I want it!
Old Jun 15, 2011 | 03:25 AM
ford390gashog's Avatar
ford390gashog
Just go with a married 205 and a divorced brownie box. I doubt you will ever use the 3 spd brownie when in 4x4 so just leave it in 1:1
Old Jun 15, 2011 | 06:12 AM
mistakenID's Avatar
mistakenID
Which is it you are going to use, a gear vendor or a brownie? A gear vendor is an over drive only. Gear Vendor calls it an over drive-under drive but they are just playing with words. They do make an under drive unit though.
A brownie or auxiliary trans can have 2,3 or 4 gears.
The adapter's on the gear vendor are all made to bolt direct to the rear of either the transmission or rear of the transfer case.
Old Jun 15, 2011 | 02:43 PM
ADTMan's Avatar
ADTMan
Brownie, i put gear vendor in there for those that might now know what a brownie is. So just don't worry about the brownie until AFTER the xfr. I do kinda doubt I need to gear lower in 4 low. It is pretty damn low now..LOL So you are probably right. Besides a married 205 is easier to find.
Old Jun 15, 2011 | 08:10 PM
joe f350's Avatar
joe f350
cant u bolt up a np205 to a t19 or 18
byerks
Apr 27, 2015 03:21 PM
Savage Fabrication
15
Jul 8, 2013 07:21 PM
TA455HO
Mar 18, 2013 10:10 AM
scottfreeman
22
May 12, 2008 06:50 AM
'88f150w/390bb
Offroad & 4x4
16
Feb 26, 2006 08:18 AM
