AIC mod
Old Jun 13, 2011 | 10:51 PM
aadams419's Avatar
aadams419
Question AIC mod
I did thr AIC mod on my truck today and it works great. I did the one with the two relays and the 5 k pot. Later I saw another post about connecting two wires with a switch activating fords pto circuit and the pcm controls rpm to 1200. I guess the question is why would you build an aic mod with a pot that is basically fooling the pcm into thinking the pedal is pushed instead of using the factory option and leting the pcm control it? I looked under the dash of my truck and there is a wire there that has a factory tag that says for pto circuit. Just wondering you guys know more about it than I do. thanks
Old Jun 13, 2011 | 10:54 PM
mueckster's Avatar
mueckster
The AIC mod allows for some adjustability. You are not limited to one preset rpm. I can crank mine up to over 2000 rpms if wanted.
Old Jun 14, 2011 | 07:58 AM
bigbubba87's Avatar
bigbubba87
What mod is this?
Old Jun 14, 2011 | 09:52 AM
nlemerise's Avatar
nlemerise
Originally Posted by bigbubba87
What mod is this?
Say after me "search is my friend..."
Old Jun 15, 2011 | 10:31 PM
aadams419's Avatar
aadams419
Thanks guys for the info
Old Jun 15, 2011 | 10:41 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I purchased the Ford AIC on bay for $15 (plus shipping). It has the ability to adjust the idle speed to whatever you like, monitors the battery voltage (on the display) and it also displays a warning when the trans temp is too high. (according to the manual...). Haven't really played with it that much yet...
It's much bigger than I expected though....the DIY mod is probably a more flexible unit as far as installation goes. Not sure where I will put the AIC because I have the F650 dash....
superduty4x4
15
Sep 6, 2021 10:50 PM
hhowell1990
Dec 14, 2012 08:24 PM
JockD
Mar 18, 2009 11:57 AM
bbsst
Nov 14, 2008 01:00 AM
hitecdan
Sep 6, 2005 10:17 PM
