Trailer disconnected warning
Old Jun 13, 2011 | 10:27 PM
HeavyTow's Avatar
HeavyTow
Has anyone experienced the trailer disconnected warning while towing and everything still being OK? I tow a 5th wheel camper and occassionally this happens. There is no pattern to when it will occur and everything is always working OK. I didn't have any problems like this with the previous truck I used to pull this trailer.
Old Jun 13, 2011 | 11:46 PM
mohle's Avatar
mohle
Do you have a second plug socket in the bed of the truck? Had a similar issue on mine and it was neither of the outlets, rather the connector that the bumper socket actually plugged into - behind the hitch.
Old Jun 14, 2011 | 05:38 AM
HeavyTow's Avatar
HeavyTow
Mohle, yes I do have one in the bed. I am using a wiring harnes that comes factory made (not Ford) that connects the two plugs together (bumper & bed plugs). It was recommended during the 5th wheel hitch installation to ensure proper working of the factory brake control. I'll check it first chance I get. It'll be probably three weeks before I get to go out with the camper again. I'll post when I get some results.
Old Jun 14, 2011 | 06:38 AM
Cowboy65's Avatar
Cowboy65
Check the following recent thread for some things to look into:
https://www.ford-trucks.com/forums/1...iodically.html
Old Jun 14, 2011 | 08:28 AM
HeavyTow's Avatar
HeavyTow
Cowboy65, thanks for the link. Looks like a good way to start. Will post when I get some answers.
Old Jun 14, 2011 | 12:40 PM
Cowboy65's Avatar
Cowboy65
Your welcome, hope some of these ideas help out. Intermittent electrical problems can be extremely frustrating problems to resolve. I had a similar problem and it turned out that I had an intermittent short in the brake wiring on my trailer. Fortunately the damaged wiring was visible, however if this had been in a hidden location it could have gone undiagnosed for a long time.
Good luck
Old Jun 14, 2011 | 10:55 PM
mohle's Avatar
mohle
Exact same setup that I've got. It's where the aftermarket harness plugs the two together. When I pinched the connector together everything worked fine. Had to replace mine in the end.
KMAPRO
Aug 27, 2016 07:27 AM
rusbukt
All Things Towing
17
Feb 12, 2016 01:35 PM
Kris_kris
Dec 16, 2015 08:48 AM
auto385
2009 - 2014 F150
Dec 6, 2011 01:38 PM
F250SD-08
Mar 18, 2011 02:09 PM
