Sponsored by: Real Truck
Separate fuses for trailer plug??
Old Aug 25, 2016 | 12:03 PM
KMAPRO's Avatar
KMAPRO
At the risk of sounding like I would be one to fall for the "blinker fluid" or "honk limit" joke....I just have to ask this question because I have never had to deal with this before.....
No matter what trailer I hook up to my truck, I can get brake lights, turn signals and flashers to work without a problem.
However, I can not get running/tail lights to work.
I have checked all of the wiring and it all looks OK. My guess is that it is the plug and that's because I will occasionally get a "beep" and warning that "trailer is disconnected"...even though I know it is.
BUT, someone mentioned something about the trailer hitch having its own separate fuses. I call BS on this, but thought I would ask and sound stupid either way...
Old Aug 25, 2016 | 12:18 PM
Sam I Am's Avatar
Sam I Am
Yes, the power distribution box under the hood contains the trailer relays and fuses.
Old Aug 25, 2016 | 02:26 PM
Chuck's First Ford's Avatar
Chuck's First Ford
Very True.. and all U.S. brand Trucks..
and has for over 10 years now. maybe 15....
read back of fuse box lid. or owners manual.
Old Aug 25, 2016 | 07:29 PM
projectSHO89's Avatar
projectSHO89
Unfortunately, you failed to identify what year you're working on, so pinpoint assistance is impossible.
Several years worth of Super Duty models have the trailer [running lamp] relay soldered into the fusebox and the relay replacement is not a simple plug and play.
Old Aug 26, 2016 | 07:06 AM
speakerfritz's Avatar
speakerfritz
by pass the hitch link for ground purposes and temporaily bolt a wire to the truck frame and the trailer frame....if everything now works trouble shoot all your trailer related grounds.
star lock washers between grounds and the frames will help.
my bet is you have a ground problem.
Old Aug 26, 2016 | 01:58 PM
projectSHO89
If it was a ground problem, it would affect ALL trailer lighting, not just the running lamps.
Old Aug 26, 2016 | 06:06 PM
ligito's Avatar
ligito
If you have dual batteries, check that, also, one may be dead.
Check all connections at the trailer connector, they can loosen.
Old Aug 27, 2016 | 07:27 AM
projectSHO89
Please explain the logic of how a bad battery (out of two in parallel), would affect ONLY the trailer running lights.
RUSTANG67
2009 - 2014 F150
Jul 18, 2015 07:25 PM
3006banger
Jul 15, 2009 07:56 AM
Ford with onions
Apr 3, 2009 02:45 PM
wat704
1997 - 2003 F150
Feb 28, 2005 10:57 PM
alpine7572
1978 - 1996 Big Bronco
Feb 10, 2003 08:20 AM
