Pulling a load: taking off - thud, braking - slam
Old Jun 13, 2011 | 07:39 AM
mechelement's Avatar
mechelement
When I pulled a load to the dump last week, I noticed something odd. From a stop light, I took off in the old truck and when it finally caught, there was a jerk/thud. It almost felt like the rear end shifted. Someone cut me off and I had to hit the brakes pretty hard and there was another thud. The one when braking felt like I hit a massive pothole or crack in the road with both front tires head one. It was more of a jolt/slam.
When I got to the dump, I had to wait in line to pay my way in and heard an awful metal grinding noise. I wasn't sure if it was my vehicle or someone elses, so I shut mine down. Sure enough it was mine. After I restarted it, no noise. It was definitely a rotational noise, not a reciprocating noise. It was a grinding.
Clutch on flywheel?
Old Jun 13, 2011 | 08:26 AM
wreckinball's Avatar
wreckinball
Take a drive and do the same thing as best you can and put your hand on the transfer case shifter, see if you feel it moving with the noises. What you are describing is the exact same thing i just went through. Odd bangs and bumps followed by the grinding sound when i was coasting at lower speeds. Yeah the transfer case **** the bed big time. The sounds and feel of it were the gears catching and letting go and when it grinds, that would be it not quite catching. Your shift mode fork, if this is the case with you, has worn through the little tabs and ate the metal. Open the drain plug a bit and collect some fluid, that will be the easy check.
Old Jun 14, 2011 | 07:04 AM
mechelement
I'll have to check this out. Did yours buck like a bronco when taking off in 1st gear?
Old Jun 14, 2011 | 10:26 AM
wreckinball
no mine is an automatic so it wouldnt but if im guessing a manual would if the xfer case was popping in and of gear. Just check the fluid. If its red and clear, then that wont be it. But if its dark and glittery, you found the problem. My fluid which i never took a vid of, looked like liquid metal.
Old Jun 14, 2011 | 10:28 AM
Aune163rd's Avatar
Aune163rd
Wow...what kind of t-case do you have? If its a BW 1356...im gonna check mine when i get home and make sure thigns are running good.
Old Jun 14, 2011 | 10:31 AM
wreckinball
1356 indeed. The old wobble in the driveline killed it off i am sure. The new one is in and running smooth!
Old Jun 14, 2011 | 01:57 PM
IDIDieselJohn's Avatar
IDIDieselJohn
My F250 would buck like bronco on a take off every now and then to... but it was mostly after sitting for at least 4-5 days without being used. I always took off in 2nd gear to (4.10) so 1st gear is pretty useless for regular driving.
But my engine had pretty bad oil leaks from just about everywhere! I always taught since it mostly happened after sitting for a bit, was oil running down on the fly-wheel, but then again if that was the cause, my clutch would of burnt out a long time ago.... so I didn't think nothing of it. lol
Old Jun 15, 2011 | 07:22 AM
mechelement
I couldn't make it thud or slam yesterday and was tired of reaching down holding the xfercase shifter for half of my commute to work.
Old Jun 15, 2011 | 11:35 AM
wreckinball
Did ya check the fluid? It might be on the verge of having more problems, but not a constant or only when under load. This could also be clutch/trans related but spinning out a drain plug on the xfer case for 1 second and looking at the fluid is the cheapest, totally free, test i can think of.
Old Jun 21, 2011 | 12:03 AM
Sycostang67's Avatar
Sycostang67
Did you figure this out? I know the BW t-cases have issues with the oil pumps failing. It makes some awful grinding noises. My friend thought it was his transmission and replaced it only to find the problem hadn't gone away. Lucky for him junkyards have a return policy so he took it back and got a t-case instead.
Old Jun 21, 2011 | 07:28 AM
mechelement
Still have not figured this out.
Old Jun 22, 2011 | 06:40 AM
PLC7.3's Avatar
PLC7.3
Do a full drive line check of all universals also......... especially the center hanger bearing.
Old Jun 22, 2011 | 07:05 AM
ADTMan's Avatar
ADTMan
Ok, so you haven't figured it out but, is it still doing it?
AKPetrohead
Aug 8, 2011 11:16 PM
Vork23
1997 - 2003 F150
Mar 20, 2011 05:40 PM
foxracer800
Feb 12, 2006 06:12 PM
Fcal
2004 - 2008 F150
Apr 1, 2005 03:56 PM
