I need help with a noise
Old Aug 7, 2011 | 02:52 AM
AKPetrohead's Avatar
AKPetrohead
So I am a new diesel owner, well a year but I think that is still new. I have put about 3K on it since I have owned it. Once in a while when I start the truck I hear a "thud" sound, almost like a door shutting. It happens about two to three seconds after start up. The "thud" is very inconsistent and at times will vary in intensity. Also it only happens once. So if any one has had this happen or has a clue on what this may be please give me a heads up. Thanks
Old Aug 7, 2011 | 06:29 AM
hammer65's Avatar
hammer65
It is the door in the Heat/ac system. Turn off the AC before starting ,and the thud goes away.
Someone on here had to explain it to me. Jim
Old Aug 7, 2011 | 11:59 AM
AKPetrohead
I'll try starting w/o AC on for a while and then try with AC. Thanks for the response.
Old Aug 7, 2011 | 12:19 PM
shorebird's Avatar
shorebird
It may just be a ventilation system door moving.
A check valve may be failing allowing the vacuum system to leak down when the truck is not running.
This may be so slow a leak that a long period needs to pass before the door has moved far enough to make a noise.
After starting the vacuum takes a moment to build up in the lines and move things to where the ***** tell them they should be.
Old Aug 7, 2011 | 01:13 PM
AKPetrohead
Hmmm, that would make sense. I'm planning on washing the truck today so I'll start it with the defrost on and see if it thumps.
Old Aug 7, 2011 | 02:05 PM
hammer65's Avatar
hammer65
Turning it off will tell you it is in the HVAC.
Old Aug 8, 2011 | 09:05 AM
AKPetrohead
Started with defrost selected, no thump. I'll let it sit this week and try one more time but more than likely start it in the off position in the future to see if the thump returns.
Old Aug 8, 2011 | 01:21 PM
hammer65's Avatar
hammer65
If you have a vacuum leak as Shorebird mentioned, the AC will default to defrost.
Someone correct me if I am wrong.
Old Aug 8, 2011 | 01:57 PM
Brother Les's Avatar
Brother Les
There is nothing wrong with your truck. It is working as it should when you have your 'temp' on a certain setting.
Old Aug 8, 2011 | 10:51 PM
AKPetrohead
Thanks B Les, I'm just going to enjoy the sounds of the 7.3.
Old Aug 8, 2011 | 11:16 PM
mudmaker's Avatar
mudmaker
Yep it is fine. My 02 did that from the day I bought it new.
RenoHuskerDu
Oct 17, 2017 09:20 AM
funfunstuie
1983 - 2012 Ranger & B-Series
Apr 20, 2017 06:28 PM
alexisvfd
Aug 5, 2013 10:31 AM
BJMF250
Jul 24, 2006 09:36 PM
4x4x4x4
Oct 17, 2002 06:37 PM
