Starter solenoid? Checking starter?
Old Sep 24, 2013 | 06:20 PM
Mcnewt's Avatar
Mcnewt
Yes '50 flat head v8. The starter bumps each time I make the connection, but does not continue to crank. Is that indicative of a bad starter?
Old Sep 24, 2013 | 06:36 PM
raytasch's Avatar
raytasch
Believe Nothing
Have you checked to see the engine is not locked up? If you put the truck in gear and push or rock it, will the engine turn?
Old Sep 24, 2013 | 06:39 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You're connecting the small wire inside the solenoid that feeds the small terminal, to the starter motor. That will burn out the solenoid. You need to ground the small terminal (IF it is the original type). If the solenoid has a button on the bottom, you can push up on it to energize.
Old Sep 24, 2013 | 07:01 PM
Mcnewt's Avatar
Mcnewt
Didn't check that, although I tried to push start it as I pushed it out of the garage, but it was just me so I assumed I wasn't rolling fast enough- I'd be surprised if the motor locked up- it was running fine before I turned the engine off.
andyofne
24
Oct 9, 2016 02:58 PM
shadetree enthusiast
Sep 18, 2014 03:39 PM
cityjack
Feb 9, 2014 08:49 PM
wilsonsuarez
Bronco II
Dec 19, 2013 07:29 AM
bluescrew
Apr 10, 2010 03:29 PM
