Custom Radiator Hoses
Old Sep 22, 2013 | 09:04 PM
tjdad62's Avatar
tjdad62
Have any of you guys used those stainless steel or braided flexible radiator hoses? If you have, what brand did you go with and how easy were they to work with? Also, have you had any leakage problems with them?
The reason I ask is that I will surely need a custom bendable lower hose to work with my radiator and to clear the PS pump on my 302 Ford. The PS pump sits on the drivers side of the engine bay and the water pump also exits out that side and the hose will need to snake around in order to go under the PS pump pulley and make the connection between the radiator and water pump.
Thanks in advance... this is on my 1950 F3 with a '91 5.0.
Old Sep 22, 2013 | 10:27 PM
52 Merc's Avatar
52 Merc
Braided stainless hose or the really cool ribbed steel hose (chrome or stainless) do not have nearly the flexibility of a generic, universal rubber flex hose. If you have really cramped quarters, the rubber will be much easier to make work.
Old Sep 23, 2013 | 08:25 PM
NPPollok's Avatar
NPPollok
I have the same setup and was able to find a rubber hose that worked. I just used a welding rod to get a rough idea of the shape I needed and looked through all the hoses at the parts store until I found one that was close.
Old Sep 23, 2013 | 08:47 PM
49f3dls's Avatar
49f3dls
I have the same setup and tried the rubber hose but the bends kinked it. Went to the stainless a d it works well. Not on road with truck yet but have run it to full temp with no leaks. Think it was from speedway or Mac's.
Old Sep 24, 2013 | 05:07 PM
bryanknie's Avatar
bryanknie
I have used the stainless ribbed hoses on may cars, easy to use, just bend and cut to length. I have used ones from summit and some no name kits from vendors at car shows, I have not had any bad luck yet, just pick them up and make sure they feel like a quality part. real tight bends could be a problem.
Old Sep 24, 2013 | 09:08 PM
Drewski 2's Avatar
Drewski 2
I'm using the ribbed stainless hose on my build. I picked them up at the Hot Rod Reunion several years ago from one of the vendors. He had marked them down due to a small chip in the chrome. Not gonna be a show truck so the chrome deal didn't bother me.
Very easy to form and fairly easy install.
THE BLUE BEAST
6.4L Power Stroke Diesel
Feb 18, 2014 08:56 PM
jackiellowery
Escape & Escape Hybrid
Feb 17, 2014 05:10 PM
abyars111
Oct 30, 2013 11:58 AM
88fordranger
Dec 12, 2005 07:32 PM
krankshaft
Aerostar
Sep 11, 2005 02:04 PM
