how do i test starter/solenoid
Old Apr 8, 2010 | 03:20 PM
bluescrew's Avatar
bluescrew
just went through fiasco of solving battery issue, my starter sounds tired.
is this what a starter sounds like when its dying? its cranking slow like the batteries arent charged (just got 2 new ones now) but it starts every time.
how can i test?
alternator is fine, tested 14V
could solenoid be causing this?
thanks
mike
Old Apr 8, 2010 | 04:25 PM
puller45's Avatar
puller45
I just replaced my starter, I,m sure the motor was good and the solenoid was bad (fell apart). You can remove the solenoid but good luck finding a replacement. I looked all over the internet and dcouldn't find a replacement solenoid. IMO, the rebuilders have the supply locked up somehow so they are the only ones who can get their hands on them= more profit. Hope you have better luck.
Old Apr 8, 2010 | 04:33 PM
bluescrew's Avatar
bluescrew
so i can bypass the solenoid to test the starter without it?
Old Apr 8, 2010 | 04:43 PM
puller45's Avatar
puller45
I suppose you can, but keep in mind that the solenoid engages the starter gear to the ring gear.You can test to see if the motor turns but not under load, so what's the use?
Old Apr 8, 2010 | 05:14 PM
bluescrew's Avatar
bluescrew
lol im at the point where i want someone to say "buy aa new starter and youll be fine"
Old Apr 8, 2010 | 05:18 PM
puller45's Avatar
puller45
I know the feeling, and that's what I did, starts fine. I also should tell you that my ordeal started with a battery fiasco too, all is well now, buy a starter and be jprepared for a shock I bought a reman from the dealer, $309.00 out the door after I gave him the core.
Old Apr 8, 2010 | 05:43 PM
fifthwheel01's Avatar
fifthwheel01
Hope I'm not too late, I just got finished putting on my new starter. Pulled it and had NAPA bench test it, is toast. I new that already just didn't wa
nt to hear it. any way- Napa just under $200 w exch.& lifetime warranty.
Old Apr 8, 2010 | 07:20 PM
bluescrew's Avatar
bluescrew
thanks fifthwheel!
Old Apr 9, 2010 | 09:13 PM
01 EXCURSION MORRIS's Avatar
01 EXCURSION MORRIS
SUBSCRIBING
Old Apr 9, 2010 | 11:45 PM
SpringerPop's Avatar
SpringerPop
01 excursion morris,
Instead of posting a "nothing" post, why not just go to the very top of the postings, in a blue bar find "Thread Tools", click on it and then click on "Subscribe to This Thread" in the drop-down menu?
Easier for you, easier than all the rest of us looking past do-nothing posts.
Just an FYI.
Pop
Old Apr 10, 2010 | 01:46 PM
fifthwheel01
Learn sometin eryday, thanks Pop
Old Apr 10, 2010 | 03:29 PM
bluescrew's Avatar
bluescrew
a little up date for you guys
it turns out my hard start is/was 3 things
battery cables- they are corroded and crappy. i hate them (ed is shipping me some new ones)
batteries- got them tested, both were bad. replaced under warranty
starter- would barely turn over this morning. truck was plugged in for 1 hour before start... used a hammer on it(tapped it a few times), and BAM truck fired right up... i will be replacing this soon.
problem solved
roosplash
Electrical Systems/Wiring
27
Apr 19, 2020 07:44 AM
user_zero
Jul 18, 2016 09:19 AM
sgauvry
Sep 22, 2015 06:47 AM
Tyler Rowe
13
Mar 8, 2013 04:35 AM
zenmaster
May 24, 2009 04:33 PM
