Heres the case. I have a 2007 250 with 6.0l of course, bone stock! Started up 3 days ago and the engine light came on and with code P0113 and P0097. Cleared codes and Immediately P0097 came back, took out IAT2 sensor cleaned it, ohmed it out and checked good. Cleared code, minute later came back, bought new sensor, installed cleared code and 15 minutes later it came back. Any ideas for another troubleshoot, I read that it might be in the harness as a short but not sure which wires to the pcm to check for continuity.......and what would the first two codes have in common?
