Replacing radiator core support - '92 F150
So I am going to replace the radiator core support in my '92 F150 as the support has entirely rotted away from both front body mounts.
I calculated from LMC and for all mounts/bolts/hardware to do this it came out to $177, without shipping included. I can find the core support online for $156 free shipping, but $177 for all the hardware is crazy. Those who have done this before, where did you order all of your hardware from? Is it really necessary to replace the two frame body mounts as well? Or just the bushings and bolts?
I think I will just replace everything. I want to get this done before winter so I'll just buy everything over time. As soon as I get my second job I'll be getting a little more $$$ to use for this project. Did you paint/undercoat your core support?
- I totally just realized I posted this in the wrong forum. It should have been in the '87-'96 forum. Oops!
I cleaned off the e-coat, then primed it, then painted it black. I did not use undercoat. I also hung new fenders, and gave them the same treatment. when you put it all back together, leave everything a little loose, and that way you can shift things around. You can leave the hood on, that gives a starting point. after you have everything so it's squared up, then fasten down the 2 bolts through the core support. take your time.put masking tape on the corners while you are shifting things around, to keep from tearing up your new paint. make sure to remove the masking tape before the sun bakes it on, it can be a real bear to remove then.
Probably Chris won't mind where you posted, because the core supports are similar between the 2 trucks.
So, I have all of the hardware, and mounts etc. Just waiting a little bit for my next paycheck to order the core support. What should I use to rust-proof everything? I was thinking Rust Bullet BlackShell. What have some of you used? I was thinking something easy like spray can rustoleum but I don't think that it will really work that well exposed to road salt and Minnesota winters.
2 months later... I finally had the radiator support replaced! I ordered the aftermarket support on eBay for around $150~ and I paid around the same for all of the bolts, bushings, etc. from LMC. I had this done at the regular shop I go to in town for $276. (I don't have any power tools) They had to do a little bit of modifying, drilling some holes larger, getting some new retainer clips, etc. since the aftermarket support was slightly different than the stock OEM support.
Rust proofed: (before going into the truck)
And also, a couple "before" pics of the rotted out support.
Passenger side: (completely rusted away from frame mount)
Driver side: (also completely separated from frame mount)
My truck definitely rides 100 times better now that the new support is in. Before, I could lift the body up off the frame in the front, and the rotted out support would just slam up and down on the frame over every bump, crack in the road etc.
Lane Locke
03-20-2017 11:27 AM
Catchad
18
06-20-2016 09:12 PM
Brown Falcon
10-20-2011 04:18 PM
brendo613
06-12-2011 09:49 AM
hasteranger
24
04-05-2011 01:09 PM
