odd sound in cab
Old Jun 9, 2011 | 08:53 PM
mormello's Avatar
mormello
odd sound in cab
when i start my truck and it idles inside the cab i hear a hissing or moving air sound like my vents are wide open even when they are off has anyone else had this problem
Old Jun 9, 2011 | 10:34 PM
Sw1tchfoot's Avatar
Sw1tchfoot
A vacuum line for your A/C and heater controls could be broken. There is a vacuum line that runs into the cab by the A/C box under the hood, you could kink it or unplug it at the source and cap the vacuum port and double check to see if the noise is gone.
Old Jun 10, 2011 | 11:24 AM
mormello's Avatar
mormello
does it matter that i dont have ac i hope thats it after a few hours of research ive seen it may be my brake booster i have a super soft peddle and stopping distance has increased and i have new pads all around
Old Jun 10, 2011 | 01:44 PM
Sw1tchfoot's Avatar
Sw1tchfoot
If you don't have A/C then you shouldn't have vacuum lines up under the dash, so scratch that.
Anyway; it probably is your brake booster.
Old Jun 10, 2011 | 02:25 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Brake Booster is the most likely culprit.
The rubber where the linkage connects the pedal to the booster is a comon place for rips or tears.
78 & 87 Super Cab
35
Jan 2, 2013 02:59 PM
SUPERDUTY OUTLAW
45
Feb 7, 2009 06:22 PM
Storm
Jan 16, 2007 07:52 AM
lbianc1
Escape & Escape Hybrid
Oct 28, 2005 07:28 PM
trevorwilliams
Feb 23, 2003 10:43 PM
