Flooding
Old Jun 9, 2011 | 09:14 AM
eric72xlt's Avatar
eric72xlt
Flooding
Hey y'all. I have a 72 F100, 390 2v I just bought. Every time I shut it off and it sits a few minutes, it floods. Have to hold pedal to the floor to start it. Not very well educated on carb tuning. Any suggestions?
Old Jun 10, 2011 | 01:24 AM
DeepRoots's Avatar
DeepRoots
problem: fuel heating up
solutions:
got spacer?
check fuel lines for routing near exhaust or other hotstuff.
Old Jun 10, 2011 | 05:26 AM
jowilker's Avatar
jowilker
Does it have an alum. intake & 4 barrel carb? A 1" phenolic spacer did the trick for me.
Truck seemed to run a little stronger with it too.
John
Old Jun 10, 2011 | 05:40 AM
eric72xlt's Avatar
eric72xlt
It is all stock. Iron intake and 2v carb. No spacer. The lines don't seem to be unusually close to anything hot. Had the breather cap off the other day and heard the carb belch, for lack of a better description.
Old Jun 10, 2011 | 08:27 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Is it flooding, or vapor locking (gas boiling) ?
If the float needle in the carb is leaking very slightly, the residual fuel pump pressure can push gas out the carb right into the intake, flooding the engine.
If it's vapor locking, which "belching" might lead me to believe, it's heat soaking into the carb or fuel lines.
Got a good fan, and a shroud?
Old Jun 10, 2011 | 08:53 AM
69cj's Avatar
69cj
Above has my vote. I had a pin hole leak in a float causing the exact same scenario. A bad seat or needle valve can also cause it.
Old Jun 10, 2011 | 08:54 AM
eric72xlt's Avatar
eric72xlt
The fan is good, aftermarket. A bit larger than stock as the shredded shroud will show. If it's a vapor lock, would holding the pedal to the floor make it start like when it's flooded?
Old Jun 10, 2011 | 09:41 AM
krewat's Avatar
krewat
Yes, I would think so. I'm trying to remember 20 years ago when my highboy used to do it
Old Jun 10, 2011 | 10:05 AM
eric72xlt's Avatar
eric72xlt
Think maybe I'm gonna attempt my 1st carb rebuild. Maybe add a spacer underneath if I can find one for a 2v.
marchare011
6.7L Power Stroke Diesel
Sep 20, 2013 11:12 PM
61 uni
Oct 13, 2012 08:42 PM
High Binder
May 21, 2011 11:17 AM
preppypyro
British Columbia
Nov 8, 2006 11:12 PM
pfogle
Aug 25, 2003 04:46 PM
