'Clear Flood' option?
Old May 20, 2011 | 01:22 PM
High Binder's Avatar
High Binder
This morning I accidentally flooded my 300ZX and had to use the 'clear flood' option (petal to the floor while cranking to turn off fuel pump) to get it started. This got me wondering if our trucks have this option, anyone know?
Old May 20, 2011 | 01:57 PM
steelhead2's Avatar
steelhead2
no.if your glow plugs arent working and its cold outside you can wash the cylinders with fuel,which will be kinda be like a "flooded" condition.youll get all kinds of white-grey smoke out of the tail pipe when it happens.happened to me once.but eventually itll fire up.
Old May 20, 2011 | 05:55 PM
XB70's Avatar
XB70
Couldn't find the clear option.
Old May 20, 2011 | 06:33 PM
william_04_x's Avatar
william_04_x
Has anyone here pinned the throttle, and started the motor with a cold engine? Did the fuel pump shut off? I know I won't try it. I'm skeered.
Old May 20, 2011 | 11:30 PM
High Binder
I'm skeerd to try it too but the 'clear flood' option is on most if not all cars these days though nobody outside of the techs/engineers seems to know about it. It only makes sense to put it on our trucks as well...
I would think one of the techs on here would know.
Old May 20, 2011 | 11:48 PM
steelhead2's Avatar
steelhead2
if you want to see a diesel flood wait til its about 15* outside,disconnect your gpcm and try to start it.you'll be able to play soccer with the smoke that's gonna roll out the tailpipe.they very seldom have problems as long as the glow plugs are working,or you plug it in.holding the pedal to the floor on a diesel will not clear it out,it'll make matters worse.
Old May 21, 2011 | 12:00 AM
High Binder
OK guys, it looks like our 6.0s do in fact have the "clear flood" feature. According to the dieselpower site and another random site our trucks do have the feature. I still would like to hear from one of our seasoned techs but it makes sense that our trucks would have the feature. I don't know if it works the same way as a gasser (assume it does) though.
Old May 21, 2011 | 12:03 AM
High Binder
Have you tried it? If the fuel pump cuts out like in a gasser than you are simply cycling the engine without fuel to clear the flood condition.
Old May 21, 2011 | 09:20 AM
dchamberlain's Avatar
dchamberlain
I seriously doubt that there is any feature that cuts out the fuel pump for any reason. Our injectors rely on fuel in them to prevent damage. That's why we spend so much time talking about fuel pressure gauges and fuel regulator upgrade springs and such.
The same thing could be accomplished by simply not firing the injectors. I have never heard of such a thing, even in gassers. But I'm sure there are a lot of things I haven't heard of.
Old May 21, 2011 | 09:39 AM
cheezit's Avatar
cheezit
simple to find out, go out and hold the pedal down and see if the pump comes on. but I dont belive it does
Old May 21, 2011 | 09:50 AM
william_04_x
You're the one with access to a bunch of trucks that aren't yours. You try it.
I'm just kidding BTW. I know cheezit's a pro.
Old May 21, 2011 | 11:17 AM
High Binder
Yeah it could be something like that on a diesel.
'Clear flood' is feature that is probably on every fuel injected car since the early 90s or late 80s.
Renegade EX
Aug 23, 2016 08:21 PM
rbloodhound
Louisiana Chapter
Mar 22, 2016 07:36 PM
Macmathews
Jan 14, 2016 10:40 AM
JRS2
Dec 17, 2015 06:41 PM
