LOOSE STEERING??
Old Jun 8, 2011 | 08:57 PM
ohiojack's Avatar
ohiojack
LOOSE STEERING??
I bought a 1978 F-100 and I noticed that the steering is really touchy. In the wind or any pot holes, the truck would wander. The tires are 235R78-15 and I haven't had the chance to check the steering linkage and kingpins yet. Any common trouble area's common on this truck? I only paid 500.00 for the truck and it's in good shape considering the age.
Old Jun 8, 2011 | 09:06 PM
montana_highboy's Avatar
montana_highboy
You got the right idea, you just need to crawl underneath the front-end while a buddy works the steering wheel back and forth, as you look for excess slop in all the usual places i.e. tie-rod ends, drag link, rag joint, ball joints or king pins, etc.
Old Jun 8, 2011 | 09:10 PM
finneys98xj's Avatar
finneys98xj
What is a good price for a front end rebuild kit?
Old Jun 8, 2011 | 09:14 PM
finneys98xj
I m looking a this kit from PST.
Performance Suspension Technology - FORD - 1/2 Ton Pickup 4WD 1972-03, Expedition 4WD 1997-02, Bronco 4WD 1978-96
Old Jun 8, 2011 | 09:46 PM
markjw's Avatar
markjw
I recently picked up a '79 that had bad wandering steering. I did like Montana highboy said and had someone turn the steering wheel back and forth while I looked under the front of the truck. Expecting to see a wore out ball joint or something common, I was surprised to see the steering box moving around. Two mounting bolts were finger tight and the third was not much better.
Old Jun 8, 2011 | 10:01 PM
Rogue_Wulff's Avatar
Rogue_Wulff
I can top that. Dad's truck was a nightmare to keep going in a straight line. Not only were 2 of the gearbox bolts loose and the 3rd not much better, but the tie rod on the bottom of the pitman arm wasn't even tight.
Of course, the cracks in the frame around the steering gear didn't help any...... nor did the missing radius arm bushing.
DieselCamper
6.4L Power Stroke Diesel
May 30, 2016 07:55 AM
Scott Yager
May 8, 2016 09:02 PM
perryg114
Feb 12, 2016 11:05 PM
Don Vito
Oct 15, 2015 03:31 PM
Wolverine69
Sep 21, 2006 03:16 PM
