egr install
Old Jun 9, 2011 | 09:35 PM
BLADE35's Avatar
BLADE35
Originally Posted by wulfman
Benny never a cel from it but my egr valve is bolted in manifold and plugged in, once in a while i'll get p401 but i toss it and i don't see him for a while,
I have never got a cel from messing with the egr [1 year unplugged in off position]
after the deleate egr valve plugged in
the scan gauge picks nothing up
my other code reader had yellow on emissions and a egr symbol flashing and a couple other ones flashing I assume it was from the batts getting unplugged and obdII had not compleated testing in all zones yet since
I will plug it in again this weekend to see if the good code reader gets anything
still no cel light whats it been a week week and half
I havent seen the infamous p0401 flow code yet
Old Jun 9, 2011 | 09:44 PM
BLADE35's Avatar
BLADE35
Originally Posted by steelhead2
hey blades,you remember the oil cooler housing bolt torque?.i didnt get any instructions,and the cooler came in the housing already.i figured it would come bare with gaskets.
steel
I went 16ft/lbs on the oil cooler housing to engine block
are those the ones your talking about
here are some tourque specs
Page 84: Appendix: Special Torque Chart A-L
Page 85: Appendix: Special Torque Chart L-V
Old Jun 9, 2011 | 10:17 PM
steelhead2's Avatar
steelhead2
Yeah,those were the ones.thanks everyone for all the help.id rep ya but I don't know how?????also,I ended up leaving the cooler loose for the install.can't believe the amount of crush on the front donut o ring needed to get the intake manifold flat on the heads.when I set it on it sure wasn't flat like I'm used to seeing.
Old Jun 9, 2011 | 10:52 PM
BLADE35's Avatar
BLADE35
click the heart in the right hand top corner of persons post you wish to rep
I noticed that donut on the intake was alot fatter than the original to
I swapedthe old oring back in it made things fit better its so fat theres no way it could leak unless damage
Old Jun 9, 2011 | 11:43 PM
steelhead2's Avatar
steelhead2
I just re used my old one.looked fine so I wasn't worried about it.an o ring that big would probably never go bad unless it was overheated.
Old Jun 11, 2011 | 10:19 AM
steelhead2's Avatar
steelhead2
Got it all in and buttoned up yesterday.fired right up and runs excellent.haven't had a chance to take it down the hiway yet but I will soon.did the blue spring and my fuel pressure went from 60 at idle and 45 at wot to a constant 75 psi.can definitely feel a difference in throttle response.one question though.....since doing the spring I can hear my fuel pump humm at idle.I'm contributing it to the increased pressure.anyone else have this happen?. The truck runs better than ever.
Old Jun 11, 2011 | 12:13 PM
BLADE35's Avatar
BLADE35
thats great steel good to see ya going again
youl be smiling now as you watch that ectvseot Im havent seen a double digit spread yet
nice not to worrey
I know what you mean about the change in stuff after new parts
since my egr deleate I swear I lost alittle turbo whistle so does the wife
that little SGII saved us from poxssible moter scatter with the oil cooler
Old Jun 11, 2011 | 01:46 PM
steelhead2's Avatar
steelhead2
Just went on my test run and only got a 2* spread.can't wait to open it up on the freeway.thanks again for the help everyone!.
Old Jun 11, 2011 | 03:47 PM
wulfman's Avatar
wulfman
Glad to hear you got it running, when i did the spring it ran much better more responsive and could hear pump run more.
EAKOCH
Dec 17, 2014 10:46 AM
pat420swed
33
Nov 15, 2014 03:05 PM
Rusty_S
Jun 6, 2013 09:51 AM
offroadnt
1983 - 2012 Ranger & B-Series
25
Apr 26, 2011 07:29 AM
BioBurner
Feb 11, 2009 10:04 PM
