egr install
Old Jun 8, 2011 | 03:39 PM
steelhead2's Avatar
steelhead2
egr install
Is it easier to leave it loose on the intake,or should I tighten it up,then install the intake back on the engine?. Looks like getting it back on the exaust will be fun.got the oil cooler in,everything buttoned up,new fuel spring and it runs lime a champ.thanks for the help,its all appreciated.one thing though,since putting in the blue spring now I can hear the fuel pump run at idle.the pressure went from sixty at idle,to fourty five at wot,too a constant seventy five psi.is it because of the pressure increase?, its gotta be.I can definitely tell a difference in throttle response.
Old Jun 8, 2011 | 05:58 PM
BLADE35's Avatar
BLADE35
hey steelhead hows it coming
might try to leave that back egr bolt loose till you get the marmon clamp lined up and tight at egr connection
I smeared my marmon clamps with antiseize it really helped alot
Its a good feeling knowing that your trucks not going to blow the oil cooler going down the road
as it gets hot weather Im shure oil cooler failure will pickup
Old Jun 8, 2011 | 06:17 PM
wulfman's Avatar
wulfman
Well i have the intake thats joined in the back and installed intake and could not get that bitch on had to take off intake , install egr cooler then put back intake pain in the assssss
Old Jun 8, 2011 | 06:23 PM
BLADE35's Avatar
BLADE35
thought that I had it easy with no cooler to get in the way
mine was connected across the back to arnt they all????
Old Jun 8, 2011 | 07:39 PM
wulfman's Avatar
wulfman
No the later ones are open , they probably make things easy
Old Jun 8, 2011 | 07:47 PM
steelhead2's Avatar
steelhead2
Mines horseshoe shaped.its going good.put the intake in a high pressure hot water parts washer for 8 hours and it came really clean.took the fuel pressure spring out and found the little black plastic round piece was in pieces though,glad I ordered the blue spring kit.so I think ill leave the cooler loose and install it that way.sounds like that'll be easiest.got parts and will start the install in the morning.one other thing,how'd you keep the intake gaskets straight when you put the intake on?.
Old Jun 8, 2011 | 08:03 PM
wulfman's Avatar
wulfman
Steel if your manifold is open in back no problem , with mine being closed in back made it imposible to get to.
Old Jun 8, 2011 | 08:32 PM
BLADE35's Avatar
BLADE35
I bolted my egr coolant suplly/ deleate on the intake and put the intake manafold back in
I dont know if this will work on the side with the egr cooler but here it goes
after I got the intake manafold back in then I put the intake gaskets in real easy with the egr cooler gone Just slipped them inbetween the two as I lifted the intake up a hair then I started the bolts anf tourque.
by sliding the gaskets in like this you eliminate the chance at ruining the gasket it sucks with the wire harness in the way to get the manafold in and gaskets lined up
If I ever pull the intake out again I will undo the intake bolts then slide the intak gasket out so I dont scrape the gasket again
make shure the locating tabs are facing up It will about line itself up as you start the bolts
Old Jun 8, 2011 | 10:11 PM
steelhead2's Avatar
steelhead2
Hey wulfman,how'd you weld your cooler?.
Old Jun 8, 2011 | 10:16 PM
BLADE35's Avatar
BLADE35
some people weld plugs in the ends of the egr cooler exhaust sides and just use the cooler for coolant flow back to the intake looks stock
Iv heard of other people put in freeze plugs not shure what size
Old Jun 9, 2011 | 04:10 AM
wulfman's Avatar
wulfman
Steel i just cut two round plugs out of 3'16 stainless and my friend tig welded them in. I did both ends just in case something breaks inside. If that happens it will just be a bigger water line.
Old Jun 9, 2011 | 10:32 AM
BLADE35's Avatar
BLADE35
I like davids plug method over the freeze plugs
david did you ever get a cel because of the cooler
Old Jun 9, 2011 | 10:39 AM
steelhead2's Avatar
steelhead2
hey blades,you remember the oil cooler housing bolt torque?.i didnt get any instructions,and the cooler came in the housing already.i figured it would come bare with gaskets.
Old Jun 9, 2011 | 03:18 PM
wulfman's Avatar
wulfman
Benny never a cel from it but my egr valve is bolted in manifold and plugged in, once in a while i'll get p401 but i toss it and i don't see him for a while,
Old Jun 9, 2011 | 06:27 PM
cheezit's Avatar
cheezit
I set mine is loose. just make sure not to cut the o-ring.
