couple random questions
Old Jun 10, 2011 | 03:31 AM
Muktown's Avatar
Muktown
Since the engine is somewhat tilted backward I pulled the foreward most plug on each head, on the drivers side it happened to be the icp and manually filled the heads with oil. Started the first crank and has been fine since! Since the icp is higher up air accumulates right there giving it faulty readings and it might take alot of cranking for it to see the 4-500 minimum to start with air right underneath it
Old Jun 10, 2011 | 06:45 AM
Neal 97 250's Avatar
Neal 97 250
I did that same thing one timer Muk. Mine cranked up the first time also. Here lately I just use the starter though. Lazy I guess.
Old Jun 10, 2011 | 11:34 AM
MagKarl's Avatar
MagKarl
Originally Posted by MHammer21
Where are these plugs on the heads and won't this introduce more air into the engine? Not sure I understand the way the oil system works, so please school me.
Thanks,
There are a couple hex head plugs on each head, they point up and inward at an angle. I don't remember the size hex, but maybe 16-17mm or so if I remember right. When you crank the starter, the hpop pushes fluid into the oil passages in the heads toward the injectors. When there is air in there, it's compressable and takes forever to build pressure. If you crack the plugs after cranking it will vent the air to the atmosphere. You'll hear it hiss air and the oil move. Top off the hpop again and repeat till you get oil from the plugs instead of air.
oasisbenk
Oct 6, 2013 08:32 PM
RideNaked
Apr 23, 2012 06:40 PM
LottaRocka
22
Nov 15, 2008 12:30 AM
nickmobile67
Oil & Lubrication
Oct 12, 2005 03:22 PM
Lead_Foot
40
Aug 30, 2005 09:34 PM
