Which replacement starter to buy???
Old Jun 7, 2011 | 09:38 AM
laidback22's Avatar
laidback22
I have a "93 f250 IDI 4x4 auto...
Original starter died last year while on the road..
Replaced it with autozone unit w/Lifetime warranty...
Died again this week, I went to pull it and the entire solenoid housing rotated while I was loosening the nut and looks to be coming apart...
I can swap it under warranty but if this is the quality level of the product I don't want to waste my time...
I have seen the Mitsu, Bosch, Denso, and the eBay brands randomly commented on and according to comment they are all wonderfull and they all suck sooo....
Is there a consensus as to which one I should buy so that a starter replacement does not become an annual affair.
Also who actually made the originals?
Thanks
Old Jun 7, 2011 | 09:42 AM
wreckinball's Avatar
wreckinball
I bought a bosch starter, new not reman. Working awesome for nearly two years now and spins the same as it did the day i bought it. Lifetime warranty through lordco auto parts here in bc canada, you might get the same from similar autoparts stores.
Old Jun 7, 2011 | 09:59 AM
Country_boy_2007's Avatar
Country_boy_2007
i bought a new napa starter, i cant remember who made it but its been on there for over a year and no problems yet, it also carries a lifetime warrenty. go for a new starter though, not a reman
Old Jun 7, 2011 | 07:16 PM
kenpobuck's Avatar
kenpobuck
Seems you got a bad one. I got mine at the zone about three yrs ago now and it still spins the beast like new. Although I uasually don't go for the big chain store stuff I bought it due to the price and warranty. But it was a new unit and not reman. Way i look at it it comes out perty easy and at free replacement I will go back as many times as I need to.
Old Jun 7, 2011 | 08:42 PM
Gevans17's Avatar
Gevans17
replacement starters
i gave up on rebuilt starters several years ago. only new for me.
Old Jun 7, 2011 | 08:51 PM
Otahyoni's Avatar
Otahyoni
I got mine from DB Electrical. Its noisy, but does a fine job.
Old Jun 8, 2011 | 07:25 AM
1bigjoe's Avatar
1bigjoe
got one from db eletrical nippisendo high torque -great-- not good---great
Old Jun 8, 2011 | 05:16 PM
tjc transport's Avatar
tjc transport
i ain't rite
same here BD electric. great starters for a great price, and only takes 3-4 days for shipping.
1988-94 FORD F- SERIES STARTER 7.3L (445) DIESEL | eBay
Old Jun 8, 2011 | 06:04 PM
Aune163rd's Avatar
Aune163rd
I got mine from Oreilly, NEW Motorcraft with a unlimited lifetime warrenty...(it was in the 86, I had a Bosch and after I bought the truck, bout six weeks later it slowly started spinning the engine slower...then longer and slower...then slower....
Old Jun 8, 2011 | 09:54 PM
Dark Horse's Avatar
Dark Horse
I am running the Autozone starter no problems so far since you have got the warranty you should collect it. when you pick up the new one make sure all the nuts bolts and screws are tight then make them put it on their tester and if it is less than perfect make them get another. every maker has a bad one sooner or later. If you just aren't satisfied buy what ever other one you like and put this one on the shelf for a spare.
Old Jun 9, 2011 | 08:07 AM
laidback22's Avatar
laidback22
Thanks all...
I was surprised ho bad the condition was on the starter... It was badly corroded all over and had even seized itself to the engine I had to use a 2x4 and a mallet to break it loose.
I took it back and the guy did not believe it was only a year old...he tested it (five times) and it was total failure. He checked serial # and was in dis-belief. the solenoid was almost rusted thru and was very loose. Anyway I'm gonna try the new on and see how it goes.
Is there any reason you guys can think of that would cause this level of corrosion it looked like the oldest part on the truck the only thing that had more rust was the exhaust manifold. I don't drive it near water, etc. and it only had about 6,000 miles on it.
Old Jun 9, 2011 | 04:53 PM
tecgod13's Avatar
tecgod13
Where do you live? If you're anywhere in the northeast, and didn't clean any of the salt off, that could happen in a year. But that seams pretty atypical that it would rust to hell in a year!
Old Jun 9, 2011 | 08:05 PM
fuzzy1626's Avatar
fuzzy1626
Another DB Electrical starter here (two years and counting).
78ferd
Apr 17, 2016 07:51 PM
Quinnbristow
1978 - 1996 Big Bronco
Jul 10, 2014 05:47 PM
David LaPell
Jan 6, 2014 12:12 PM
hotrodharley84
May 21, 2013 12:17 PM
F250_
49
Jun 5, 2011 04:38 PM
