302 clevor engine?
Old Jun 6, 2011 | 09:14 PM
skates21's Avatar
skates21
302 clevor engine?
Is it worth it to build ?
Old Jun 7, 2011 | 01:36 AM
cjben's Avatar
cjben
not unless you are just wanting something unique. There are pretty much limitless options for the 351w these days,and can be built cheaper than the clevor.
Old Jun 7, 2011 | 08:29 AM
skates21's Avatar
skates21
Thanks I heard that from a few people so far.
Old Jun 7, 2011 | 11:18 AM
Conanski's Avatar
Conanski
Aftermarket Windsor heads that match and exceed what the old Cleveland heads did are plentiful and cheap, and they don't require a special intake manifold or any of the modifications that the cleveland heads need to work on a Windsor block.
Old Jun 7, 2011 | 01:15 PM
skates21's Avatar
skates21
How would they do on a 302?
Old Jun 8, 2011 | 03:05 AM
xlt4wd90's Avatar
xlt4wd90
You can build it up like the original Boss 302, which was pretty weak up to about 4000 rpm, then it would scream up to 8000 rpm, when the bottom end would disintegrate. They were really only good for lightweight cars, like a Mustang, on high speed tracks.
I collected parts for building up a "Boss" 351 using B&A's Track Boss manifold and a pair of Australian 2V heads. Then I found out the cost to machine and build up the heads so they had good flow was more than what a good set of modern aluminum heads, complete, would cost. So I have some parts I don't know what to do with, including a pair of Aussie heads in need of complete revuild and a set of those funky valve cover/stud stabilizers that only fit Cleveland style heads.
Old Jun 8, 2011 | 12:06 PM
skates21's Avatar
skates21
Originally Posted by xlt4wd90
You can build it up like the original Boss 302, which was pretty weak up to about 4000 rpm, then it would scream up to 8000 rpm, when the bottom end would disintegrate. They were really only good for lightweight cars, like a Mustang, on high speed track.
So I were going to build one the 351 would be the way I need to go. I really am not wanting to race my truck but I do want power on demand . I can't decide on the 351w or stay with the 302w. Also I want a deep rumble from exhaust.
Old Jun 8, 2011 | 02:18 PM
xlt4wd90's Avatar
xlt4wd90
For a truck, I would definitely go with a 351, maybe stroking it to 408. However, I hear that the new Coyote 5 liter engine does amazing things in a truck, but may cost a lot to get. In either case, I'm sure you can find an exhaust system to give you the rumble you're looking for.
Old Jun 10, 2012 | 07:46 PM
pcmenten's Avatar
pcmenten
Is a Clevor 302 worth the trouble? Your call. Might be interesting to put one in a Fox Mustang. If you could get some Aussie 302C heads to put onto a roller block, stroke it to 3.25", you'd have a peppy little runner. You'd have to notch the pistons to clear the intake valves.
I've heard that the 85 or 86 roller blocks had thick walls. If you could bore one of those to 4.1", you'd have an interesting 343" engine.
Edelbrock makes a 4bbl intake for the 302 Clevor. Summit sells it for $260.
The canted valves just flow better than the typical in-line Windsor valve. Low-lift flow is better. The valves are pretty big on Clevelands; 2.05" on the 2v heads. Valve sizes are restricted on Windsor heads, usually to about 2.02".
The open-chamber heads flow well and you can improve on that by using 30 degree valve angles instead of the usual 45 degree angles.
Just sayin'.
Old Jun 10, 2012 | 09:19 PM
Ken(Ark)'s Avatar
Ken(Ark)
I wish I had a dollar for every time I heard some young kid say he had a boss 302 in his mustang .
It would be a cool combo
Old Jun 10, 2012 | 09:33 PM
pcmenten's Avatar
pcmenten
Hi Ken. If I didn't already have unfinished projects, I would consider a Boss 302 build for my 86 Mustang GT. I'd like to find someone to weld up a EFI manifold for the Boss/Clevor combination. I think the GT40 intake has round ports up to the point where it bolts to the heads. Those round ports would mate up well to the round Cleveland ports.
Old Jun 11, 2012 | 07:13 AM
baddad457's Avatar
baddad457
Just sayin'.
I've been thinkin on doing a 3.25" stroke Boss 302, there are off the shelf pistons for this, Probe makes em, but they're not cheap at $500 a set. I have a Hi-po main capped D8VE block that'll go .080 to use, I just haven't priced the custom pistons for that bore/stroke yet. And got a friend whose got a few sets of 4 bbl Cleveland heads he'll never use. I've yet to find a roller block that'll go that far, most are pretty much done at std bore.
Old Jun 11, 2012 | 07:15 AM
baddad457's Avatar
baddad457
You'd do better using a truck lower, the ports are far larger than the GT40 on the topside.
Old Jun 24, 2012 | 12:11 AM
BEWOLD's Avatar
BEWOLD
I see its been awhile for this discussion but Trick flow makes a few manifolds for clevors, even a 5.0 style fuelie set up I think that would kick ***. CHI makes some wicked heads to build clevors as well. Jon Kasse has used them to win the engine masters a couple times. agreed new windsor heads exceed old clevelands, but you will still have to spend big bucks to get a modern windsor head that flows like a modern cleveland.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
